A New Approach to Linear Filtering and Prediction Problems, Journal of Basic Engineering, vol.82, issue.1, pp.35-45, 1960. ,
DOI : 10.1115/1.3662552
Observing the State of a Linear System, IEEE Transactions on Military Electronics, vol.8, issue.2, pp.74-80, 1964. ,
DOI : 10.1109/TME.1964.4323124
High gain observers with updated gain and homogeneous correction terms, Automatica, vol.45, issue.2, pp.422-428, 2009. ,
DOI : 10.1016/j.automatica.2008.07.015
URL : https://hal.archives-ouvertes.fr/hal-00362752
Observer Design for Nonlinear Systems Under Unknown Time-Varying Delays, IEEE Transactions on Automatic Control, vol.58, issue.6, pp.1529-1534, 2013. ,
DOI : 10.1109/TAC.2012.2225554
URL : https://hal.archives-ouvertes.fr/hal-00749682
Interval observers for linear time-invariant systems with disturbances, Automatica, vol.47, issue.1, pp.140-147, 2011. ,
DOI : 10.1016/j.automatica.2010.10.019
URL : https://hal.archives-ouvertes.fr/hal-00555464
Fault Diagnosis and Fault-Tolerant Control and Guidance for Aerospace Vehicles, 2014. ,
DOI : 10.1007/978-1-4471-5313-9
URL : https://hal.archives-ouvertes.fr/hal-00869253
Data Assimiliation: Making Sense of Observations, 2010. ,
Time-Varying Parameter Identification Algorithms: Finite and Fixed-Time Convergence, IEEE Transactions on Automatic Control, vol.62, issue.7, 2017. ,
DOI : 10.1109/TAC.2017.2673413
URL : https://hal.archives-ouvertes.fr/hal-01470957
A continuous-time observer which converges in finite time, IEEE Transactions on Automatic Control, vol.47, issue.7, pp.1202-1204, 2002. ,
DOI : 10.1109/TAC.2002.800673
Homogeneous Approximation, Recursive Observer Design, and Output Feedback, SIAM Journal on Control and Optimization, vol.47, issue.4, pp.1814-1850, 2008. ,
DOI : 10.1137/060675861
URL : https://hal.archives-ouvertes.fr/hal-00362707
Finite-Time Observers: Application to Secure Communication, IEEE Transactions on Automatic Control, vol.53, issue.1, pp.356-360, 2008. ,
DOI : 10.1109/TAC.2007.914264
URL : https://hal.archives-ouvertes.fr/inria-00176758
Finite time stabilization of a perturbed double integrator - Part II: applications to bipedal locomotion, 49th IEEE Conference on Decision and Control (CDC), pp.3554-3559, 2010. ,
DOI : 10.1109/CDC.2010.5717010
On sliding mode observers for systems with unknown inputs, International Journal of Adaptive Control and Signal Processing, vol.21, pp.8-9, 2007. ,
DOI : 10.1109/vss.2006.1644520
URL : https://hal.archives-ouvertes.fr/inria-00171472
High-gain observers in nonlinear feedback control, International Journal of Robust and Nonlinear Control, vol.58, issue.9, pp.993-1015, 2014. ,
DOI : 10.1137/1.9780898718683
URL : https://hal.archives-ouvertes.fr/hal-01248861
Robust exact differentiation via sliding mode technique, Automatica, vol.34, issue.3, pp.379-384, 1998. ,
DOI : 10.1016/S0005-1098(97)00209-4
Uniform Robust Exact Differentiator, IEEE Transactions on Automatic Control, vol.56, issue.11, pp.2727-2733, 2011. ,
DOI : 10.1109/TAC.2011.2160030
Robust exact uniformly convergent arbitrary order differentiator, Automatica, vol.49, issue.8, pp.2489-2495, 2013. ,
DOI : 10.1016/j.automatica.2013.04.034
Finite-time and fixed-time observers design via implicit Lyapunov function, 2016 European Control Conference (ECC), 2016. ,
DOI : 10.1109/ECC.2016.7810300
URL : https://hal.archives-ouvertes.fr/hal-01298162
On finite stability in control systems, Rendiconti del Circolo Matematico di Palermo, vol.XV, issue.3, pp.273-283, 1966. ,
DOI : 10.1007/BF02849435
Finite-Time Stability of Continuous Autonomous Systems, SIAM Journal on Control and Optimization, vol.38, issue.3, pp.751-766, 2000. ,
DOI : 10.1137/S0363012997321358
Finite Time Stability and Robust Control Synthesis of Uncertain Switched Systems, SIAM Journal on Control and Optimization, vol.43, issue.4, pp.1253-1271, 2005. ,
DOI : 10.1137/S0363012903425593
Nonlinear Feedback Design for Fixed-Time Stabilization of Linear Control Systems, IEEE Transactions on Automatic Control, vol.57, issue.8, pp.2106-2110, 2012. ,
DOI : 10.1109/TAC.2011.2179869
URL : https://hal.archives-ouvertes.fr/hal-00757561
Finite-time and fixed-time stabilization: Implicit Lyapunov function approach, Automatica, vol.51, pp.332-340, 2015. ,
DOI : 10.1016/j.automatica.2014.10.082
URL : https://hal.archives-ouvertes.fr/hal-01098099
Introduction to calculus and analysis (, 2000. ,
A general approach to synthesis problem, Doklady Academii Nauk SSSR, vol.248, pp.1051-1063, 1979. ,
Soft variable-structure controls: a survey, Automatica, vol.40, issue.11, pp.1821-1844, 2004. ,
DOI : 10.1016/j.automatica.2004.05.017
Differential equations with discontinuous right-hand side, 1988. ,
DOI : 10.1090/trans2/042/13
Lyapunov Functions and Stability in Control Theory, 2005. ,
Verification of ISS, iISS and IOSS properties applying weighted homogeneity, Systems & Control Letters, vol.62, issue.12, pp.1159-1167, 2013. ,
DOI : 10.1016/j.sysconle.2013.09.004
URL : https://hal.archives-ouvertes.fr/hal-00877148
Nonlinear Observers Robust to Measurement Disturbances in an ISS Sense, IEEE Transactions on Automatic Control, vol.61, issue.1, pp.48-61, 2016. ,
DOI : 10.1109/TAC.2015.2423911
Input to state stability and allied system properties, Automation and Remote Control, vol.72, issue.8, pp.1579-1614, 2011. ,
DOI : 10.1134/S0005117911080017
URL : https://hal.archives-ouvertes.fr/hal-00639491
Linear Multivariable Control: A Geometric Approach The block control design principle I, Automation and Remote Control, vol.51, issue.5, pp.601-608, 1985. ,
Pole placement for controlling a large scale power system, Automation and Remote Control, vol.72, issue.10, pp.2123-2146, 2011. ,
DOI : 10.1134/S0005117911100110
Nonlinear Control Systems, 1995. ,
A Nonlinear High-Gain Observer for Systems With Measurement Noise in a Feedback Control Framework, IEEE Transactions on Automatic Control, vol.58, issue.3, pp.569-580, 2013. ,
DOI : 10.1109/TAC.2012.2218063
On the performance of high-gain observers with gain adaptation under measurement noise, Automatica, vol.47, issue.10, pp.2165-2176, 2011. ,
DOI : 10.1016/j.automatica.2011.08.002
URL : https://hal.archives-ouvertes.fr/hal-00643452
Fixed-time observer with simple gains for uncertain systems, Automatica, vol.81, issue.7, pp.438-446, 2017. ,
DOI : 10.1016/j.automatica.2017.04.009
URL : https://hal.archives-ouvertes.fr/hal-01516988
