Orthogonality regularizer for question answering - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Learning embeddings of words and knowledge base elements is a promising approach for open domain question answering. Based on the remark that relations and entities are distinct object types lying in the same embedding space, we analyze the benefit of adding a regularizer favoring the embeddings of entities to be orthogonal to those of relations. The main motivation comes from the observation that modifying the embeddings using prior knowledge often helps performance. The experiments show that incorporating the regularizer yields better results on a challenging question answering benchmark.
orthogonality.pdf (157.13 Ko) Télécharger le fichier
hal-01623819 , version 1 (25-10-2017)
Chunyang Xiao, Guillaume Bouchard, Marc Dymetman, Claire Gardent. Orthogonality regularizer for question answering. *SEM 2016,. The Fifth Joint Conference on Lexical and Computational Semantics, Aug 2016, Berlin, Germany. pp.142 - 147, ⟨10.18653/v1/S16-2019⟩. ⟨hal-01623819⟩
406 Consultations
82 Téléchargements
