Higher order Moreau's sweeping process: Mathematical formulation and numerical simulation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematical Programming Année : 2008
In this paper we present an extension of Moreau's sweeping process for higher order systems. The dynamical framework is carefully introduced, qualitative, dissipativity, stability, existence, regularity and uniqueness results are given. The time-discretization of these nonsmooth systems with a time-stepping algorithm is also presented. This differential inclusion can be seen as a mathematical formulation of complementarity dynamical systems with arbitrary dimension and arbitrary relative degree between the complementary-slackness variables. Applications of such high-order sweeping processes can be found in dynamic optimization under state constraints and electrical circuits with ideal diodes.
VABBDG.pdf (1.72 Mo) Télécharger le fichier
inria-00423566 , version 1 (29-10-2017)
Vincent Acary, Bernard Brogliato, Daniel Goeleven. Higher order Moreau's sweeping process: Mathematical formulation and numerical simulation. Mathematical Programming, 2008, 113 (1), pp.133-217. ⟨10.1007/s10107-006-0041-0⟩. ⟨inria-00423566⟩
586 Consultations
197 Téléchargements
