Derivation of the stochastic Burgers equation with Dirichlet boundary conditions from the WASEP
Abstract : We consider the weakly asymmetric simple exclusion process on the discrete space $\{1,...,n-1\}$, in contact with stochastic reservoirs, both with density $\rho\in{(0,1)}$ at the extremity points, and starting from the invariant state, namely the Bernoulli product measure of parameter $\rho$. Under time diffusive scaling $tn^2$ and for $\rho=\frac12$, when the asymmetry parameter is taken of order $1/ \sqrt n$, we prove that the density fluctuations at stationarity are macroscopically governed by the energy solution of the stochastic Burgers equation with Dirichlet boundary conditions, which is shown to be unique and different from the Cole-Hopf solution.
Type de document :
Pré-publication, Document de travail
69 pages. 2017
Liste complète des métadonnées
Littérature citée [41 références]  Voir  Masquer  Télécharger
https://hal.inria.fr/hal-01626604
Contributeur : Marielle Simon <>
Soumis le : vendredi 8 décembre 2017 - 09:29:04
Dernière modification le : mercredi 13 février 2019 - 01:23:55
Fichier
SBE_DBC_PTRF.pdf
Fichiers produits par l'(les) auteur(s)
  • HAL Id : hal-01626604, version 1
  • ARXIV : 1710.11011
Collections
Citation
Patricia Gonçalves, Nicolas Perkowski, Marielle Simon. Derivation of the stochastic Burgers equation with Dirichlet boundary conditions from the WASEP. 69 pages. 2017. 〈hal-01626604〉
Métriques
Consultations de la notice
273
Téléchargements de fichiers
51
