A new improved version of the realistic digital brain phantom, NeuroImage, vol.32, issue.1, pp.138-145, 2006. ,
DOI : 10.1016/j.neuroimage.2006.03.052
Iterative total variation schemes for nonlinear inverse problems, Inverse Problems, vol.25, issue.10, p.105004, 2009. ,
DOI : 10.1088/0266-5611/25/10/105004
Fast Gradient-Based Algorithms for Constrained Total Variation Image Denoising and Deblurring Problems, IEEE Transactions on Image Processing, vol.18, issue.11, pp.2419-2434, 2009. ,
DOI : 10.1109/TIP.2009.2028250
URL : http://ie.technion.ac.il/%7Ebecka/papers/new-vers6.pdf
Phase reconstruction from velocity-encoded MRI measurements ??? A survey of sparsity-promoting variational approaches, Journal of Magnetic Resonance, vol.238, pp.26-43, 2014. ,
DOI : 10.1016/j.jmr.2013.10.003
Handbook of MRI pulse sequences, 2004. ,
Undersampled radial mri with multiple coils. iterative image reconstruction using a total variation constraint. Magnetic resonance in medicine, pp.1086-1098, 2007. ,
Variable Metric Inexact Line-Search-Based Methods for Nonsmooth Optimization, SIAM Journal on Optimization, vol.26, issue.2, 2015. ,
DOI : 10.1137/15M1019325
URL : http://arxiv.org/pdf/1506.00385
Compressive sampling, Proceedings of the international congress of mathematicians, pp.1433-1452, 2006. ,
A First-Order Primal-Dual Algorithm for Convex Problems with??Applications to Imaging, Journal of Mathematical Imaging and Vision, vol.60, issue.5, pp.120-145, 2011. ,
DOI : 10.1007/978-3-540-74936-3_22
URL : https://hal.archives-ouvertes.fr/hal-00490826
Compressed sensing. Information Theory, IEEE Transactions on, vol.52, issue.4, pp.1289-1306, 2006. ,
Applications of the method of multipliers to variational inequalities. Studies in mathematics and its applications, pp.299-331, 1983. ,
The Split Bregman Method for L1-Regularized Problems, SIAM Journal on Imaging Sciences, vol.2, issue.2, pp.323-343, 2009. ,
DOI : 10.1137/080725891
Parallel imaging with nonlinear reconstruction using variational penalties, Magnetic Resonance in Medicine, vol.64, issue.1, pp.34-41, 2012. ,
DOI : 10.1002/mrm.22483
URL : http://onlinelibrary.wiley.com/doi/10.1002/mrm.22964/pdf
The Primal-Dual Hybrid Gradient Method for Semiconvex Splittings, SIAM Journal on Imaging Sciences, vol.8, issue.2, pp.827-857, 2015. ,
DOI : 10.1137/140976601
Variational Depth From Focus Reconstruction, IEEE Transactions on Image Processing, vol.24, issue.12, pp.5369-5378, 2015. ,
DOI : 10.1109/TIP.2015.2479469
iPiano: Inertial Proximal Algorithm for Nonconvex Optimization, SIAM Journal on Imaging Sciences, vol.7, issue.2, pp.1388-1419, 2014. ,
DOI : 10.1137/130942954
URL : http://lmb.informatik.uni-freiburg.de/Publications/2014/OB14/ipiano.pdf
Parallel mr image reconstruction using augmented lagrangian methods. Medical imaging, IEEE Transactions on, vol.30, issue.3, pp.694-706, 2011. ,
DOI : 10.1109/tmi.2010.2093536
URL : https://www.ncbi.nlm.nih.gov/pmc/articles/PMC3081617/pdf
Convex analysis (princeton mathematical series), p.49, 1970. ,
Nonlinear total variation based noise removal algorithms, Physica D: Nonlinear Phenomena, vol.60, issue.1, pp.259-268, 1992. ,
maps by projection into a spherical functions space, Magnetic Resonance in Medicine, vol.1, issue.1, pp.394-401, 2014. ,
DOI : 10.1002/mrm.1910010107
Image reconstruction by regularized nonlinear inversion-Joint estimation of coil sensitivities and image content, Magnetic Resonance in Medicine, vol.52, issue.3, pp.674-682, 2008. ,
DOI : 10.1007/978-94-009-1740-8
A primal???dual hybrid gradient method for nonlinear operators with applications to MRI, Inverse Problems, vol.30, issue.5, p.55012, 2014. ,
DOI : 10.1088/0266-5611/30/5/055012
A Unified Primal-Dual Algorithm Framework Based on??Bregman Iteration, Journal of Scientific Computing, vol.1, issue.1, pp.20-46, 2011. ,
DOI : 10.4310/CMS.2010.v8.n1.a6
URL : https://link.springer.com/content/pdf/10.1007%2Fs10915-010-9408-8.pdf
