Tillman Extension of p-Laplace Operator for Image Denoising, p.107 ,
Carola-Bibiane Schönlieb, and Tuomo Valkonen Regularized Optimal Design Problem for a Viscoelastic Plate Vibrating Against a Rigid Obstacle, 127 Igor Bock Optimal Abort Landing in the Presence of Severe Windshears . . . . . . . . . . . 137 ,
Turova Dynamic Programming Approach for Discrete-Valued Time Discrete Optimal Control Problems with Dwell Time Constraints, p.159 ,
Phase Multi-criteria Server Selection for Lightweight Video Distribution Systems, 189 Octavian Catrina ,
220 Ioannis K. Dassios and Krzysztof J. Szajowski Differentials and Semidifferentials for Metric Spaces of Shapes, 230 Michel C. Delfour Necessary Optimality Conditions in a Problem with Integral Equations on a Nonfixed Time Interval Subject to Mixed and State Constraints, p.240 ,
Criterion for Robust Stability with Respect to Parametric Uncertainties Modeled by Multiplicative White Noise with Unknown Intensity, with Applications to Stability of, Neural Networks, p.250 ,
261 M. Hassan Farshbaf-Shaker and Noriaki Yamazaki X Contents Derivation of a Macroscopic LWR Model from a Microscopic follow-the-leader Model by Homogenization, 272 Nicolas Forcadel and Mamdouh Zaydan ,
Sofonea On the Solvability of a Nonlinear Tracking Problem Under Boundary Control for the Elastic Oscillations Described by Fredholm Integro-Differential Equations, 312 Akylbek Kerimbekov and Elmira Abdyldaeva Observability of a Ring Shaped Membrane via Fourier Series. . . . . . . . . . . . 322 ,
and Michel Mehrenberger A Mixed Approach to Adjoint Computation with Algorithmic Differentiation, p.331 ,
Albring Sparsity Constrained Image Restoration: An Approach Using the Newton Projection Method ,
360 Vyacheslav Maksimov On the Weak Solvability and the Optimal Control of a Frictional Contact Problem with, Normal Compliance . . . . . . . . . . . . . . . . . . . . . . . . . Andaluzia Matei, vol.370 ,
Hiptmair Contents XI Exploitation of the Value Function in a Bilevel Optimal Control Problem, p.410 ,
420 Laetitia Paoli A Complex Mathematical Model with Competition in Leukemia with Immune Response -An Optimal Control Approach, 442 Á. Rodríguez-Arós, M.T. Cao-Rial, and M. Sofonea Optimization of Engineering Processes Including Heating in Time-Dependent Domains, p.452 ,
462 Nina Subbotina and Lyubov Shagalova Dynamic Programming to Reconstruction Problems for a Macroeconomic Model, p.472 ,
Krupennikov Stable Sequential Pontryagin Maximum Principle as a Tool for Solving Unstable Optimal Control and Inverse Problems for Distributed Systems, p.482 ,
493 Domingo Alberto Tarzia Modeling and Control of Low-Frequency Electromagnetic Fields in Multiply Connected Conductors, p.505 ,
Valli Parameter Estimation Algorithms for Kinetic Modeling from Noisy Data, p.517 ,
