Necessary Conditions for Optimal Terminal Time Control Problems Governed by a Volterra Integral Equation, Journal of Optimization Theory and Applications, vol.16, issue.1, pp.79-93, 2006. ,
DOI : 10.1007/s10957-006-9087-7
Optimal control of state constrained integral equations . Set-Valued Var, Anal, vol.1834, pp.307-326, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00473952
First- and Second-Order Optimality Conditions for Optimal Control Problems of State Constrained Integral Equations, Journal of Optimization Theory and Applications, vol.1, issue.2, pp.1-40, 2013. ,
DOI : 10.2140/pjm.1951.1.525
URL : https://hal.archives-ouvertes.fr/hal-00697504
Optimal control problem with an integral equation as the control object, Nonlinear Analysis: Theory, Methods & Applications, vol.72, issue.3-4, pp.1235-1246, 2010. ,
DOI : 10.1016/j.na.2009.08.008
Maximum principle in optimal control, 2004. ,
Necessary Conditions for a Weak Minimum in Optimal Control Problems with Integral Equations Subject to State and Mixed Constraints, SIAM Journal on Control and Optimization, vol.52, issue.6, pp.3437-3462, 2014. ,
DOI : 10.1137/130921465
Necessary conditions for a weak minimum in optimal control problems with integral equations on a variable time interval. Discrete and Continuous Dynamical Systems, ser, pp.4323-4343, 2015. ,
