Solving mixed-integer optimal control problems by branch&bound: a case study from automobile test-driving with gear shift, Optimal Control Applications and Methods, vol.83, issue.1, pp.1-18, 2005. ,
DOI : 10.1007/978-3-642-86470-4
A variable time transformation method for mixed-integer optimal control problems, Optimal Control Applications and Methods, vol.83, issue.3, pp.169-182, 2006. ,
DOI : 10.1007/978-3-642-80684-1
Optimal control of ODEs and DAEs, DeGruyter, 2011. ,
DOI : 10.1515/9783110249996
Modeling and optimizing traffic light settings in road networks, Computers & Operations Research, vol.55, pp.36-51, 2015. ,
DOI : 10.1016/j.cor.2014.10.001
Optimal strategies for the control of a train, Automatica, vol.32, issue.4, pp.519-532, 1996. ,
DOI : 10.1016/0005-1098(95)00184-0
A Combinatorial, Graph-Based Solution Method for a Class of Continuous-Time Optimal Control Problems, Mathematics of Operations Research, vol.27, issue.2, pp.312-325, 2002. ,
DOI : 10.1287/moor.27.2.312.325
Fast numerical methods for mixed-integer nonlinear model-predictive control, Naturwissenschaftlich-Mathematische Gesamtfakultät, 2010. ,
DOI : 10.1007/978-3-8348-8202-8
Time-optimal control of automobile test drives with gear shifts. Optimal Control Applications and Methods, 2010. ,
An optimal control approach to nonlinear mixed integer programming problems, Computers & Mathematics with Applications, vol.36, issue.3, pp.87-105, 1998. ,
DOI : 10.1016/S0898-1221(98)00131-X
URL : https://doi.org/10.1016/s0898-1221(98)00131-x
Control parameterization enhancing technique for time optimal control problems, Dynamic Systems and Applications, vol.6, issue.2, pp.243-262, 1997. ,
Control parametrization enhancing technique for optimal discrete-valued control problems, Automatica, vol.35, issue.8, pp.351401-1407, 1999. ,
DOI : 10.1016/S0005-1098(99)00050-3
Mathematical Programs with Blocks of Vanishing Constraints Arising in Discretized Mixed-Integer Optimal Control Problems. Set- Valued and Variational Analysis, pp.149-167, 2015. ,
Reformulations and algorithms for the optimization of switching decisions in nonlinear optimal control, Journal of Process Control, vol.19, issue.8, pp.1238-1247, 2009. ,
DOI : 10.1016/j.jprocont.2009.03.008
Numerical Methods for Optimal Control with Binary Control Functions Applied to a Lotka-Volterra Type Fishing Problem, Recent Advances in Optimization (Proceedings of the 12th French-German-Spanish Conference on Optimization), volume 563 of Lectures Notes in Economics and Mathematical Systems, pp.269-289, 2006. ,
DOI : 10.1007/3-540-28258-0_17
Fast solution of periodic optimal control problems in automobile test-driving with gear shifts, 2008 47th IEEE Conference on Decision and Control, pp.1563-1568, 2008. ,
DOI : 10.1109/CDC.2008.4739014
Numerical methods for mixed-integer optimal control problems, Univ. Heidelberg, Naturwissenschaftlich-Mathematische Gesamtfakultät (Diss.). viii, 2006. ,
Direct methods with maximal lower bound for mixed-integer optimal control problems, Mathematical Programming, vol.11, issue.E, pp.109-149, 2009. ,
DOI : 10.1016/S0098-1354(97)87544-8
Numerical Methods for Robust, Singular and Discrete Valued Optimal Control Problems, 2004. ,
The control parameterization enhancing transform for constrained optimal control problems, The Journal of the Australian Mathematical Society. Series B. Applied Mathematics, vol.4, issue.03, pp.314-335, 1999. ,
DOI : 10.1016/0005-1098(93)90076-6
URL : https://www.cambridge.org/core/services/aop-cambridge-core/content/view/A0AC2BCCE5B25DE93AFE147330860B52/S0334270000010936a.pdf/div-class-title-the-control-parameterization-enhancing-transform-for-constrained-optimal-control-problems-div.pdf
