On Solutions of Elliptic Equations Satisfying Mixed Boundary Conditions, SIAM Journal on Mathematical Analysis, vol.13, issue.2, pp.254-262, 1982. ,
DOI : 10.1137/0513018
Optimal control of an obstacle problem, Applied Mathematics & Optimization, vol.5, issue.5, pp.147-172, 1997. ,
DOI : 10.1080/02331938308842851
URL : https://hal.archives-ouvertes.fr/hal-00023024
The mathematical theory of finite element methods, 2008. ,
Uniform convergence of the FEM. Applications to state constrained control problems, Comput. Appl. Math, vol.21, pp.67-100, 2002. ,
Dirichlet contol problems in smooth and nonsmooth convex plain domains. Control Cybernetics, pp.931-955, 2011. ,
Error Estimates for the Numerical Approximation of Dirichlet Boundary Control for Semilinear Elliptic Equations, SIAM Journal on Control and Optimization, vol.45, issue.5, pp.1586-1611, 2006. ,
DOI : 10.1137/050626600
The finite element method for elliptic problems, SIAM, 2002. ,
Finite element approximation of elliptic control problems with constraints on the gradient, Numerische Mathematik, vol.15, issue.5, pp.335-350, 2009. ,
DOI : 10.1007/978-3-642-61798-0
Convergence of a Finite Element Approximation to a State-Constrained Elliptic Control Problem, SIAM Journal on Numerical Analysis, vol.45, issue.5, pp.1937-1953, 2007. ,
DOI : 10.1137/060652361
Convergence of Distributed Optimal Controls on the Internal Energy in Mixed Elliptic Problems when the Heat Transfer Coefficient Goes to Infinity, Applied Mathematics and Optimization, vol.47, issue.3, pp.213-230, 2003. ,
DOI : 10.1007/s00245-003-0761-y
A new proof of the convergence of the distributed optimal controls on the internal energy in mixed elliptic problems, MAT ? Serie A, vol.7, pp.31-42, 2004. ,
H??lder Continuity and Optimal Control for Nonsmooth Elliptic Problems, Applied Mathematics and Optimization, vol.190, issue.1, pp.397-428, 2009. ,
DOI : 10.1007/978-1-4612-1015-3
Moreau???Yosida Regularization in State Constrained Elliptic Control Problems: Error Estimates and Parameter Adjustment, SIAM Journal on Numerical Analysis, vol.47, issue.3, pp.1666-1683, 2009. ,
DOI : 10.1137/080718735
A Variational Discretization Concept in Control Constrained Optimization: The Linear-Quadratic Case, Computational Optimization and Applications, vol.30, issue.1, pp.45-61, 2005. ,
DOI : 10.1007/s10589-005-4559-5
URL : https://hal.archives-ouvertes.fr/hal-01395598
A note on variational dicretization of elliptic Nuemann boundary control. Control Cybernetics, pp.577-591, 2009. ,
An introduction to variational inequalities and their applications, SIAM, 2000. ,
DOI : 10.1137/1.9780898719451
The mixed problem in L p for some two-dimensional Lipschitz domains, Mathematische Annalen, vol.59, issue.2, pp.91-124, 2008. ,
DOI : 10.1007/BFb0091154
Contrôle optimal des systèmes gouvernés par des équations aux dérivées partielles, 1968. ,
Numerical Approximation of a Unilateral Obstacle Problem, Journal of Optimization Theory and Applications, vol.152, issue.1, pp.177-194, 2012. ,
DOI : 10.1007/978-3-662-12613-4
Regularization of mixed second-order elliptic problems, Israel Journal of Mathematics, vol.67, issue.2, pp.150-168, 1968. ,
DOI : 10.5802/aif.232
Sufficient and/or necessary condition for the heat transfer coefficient on 1 ,
An inequality for the constant heat flux to obtain a steady-state two-phase Stefan problem, Engineering Analysis, vol.5, issue.4, pp.177-181, 1988. ,
DOI : 10.1016/0264-682X(88)90013-5
Numerical Analysis for the Heat Flux in a Mixed Elliptic Problem to Obtain a Discrete Steady-State Two-Phase Stefan Problem, SIAM Journal on Numerical Analysis, vol.33, issue.4, pp.1257-1265, 1996. ,
DOI : 10.1137/S0036142993240187
URL : https://hal.archives-ouvertes.fr/inria-00074967
Numerical analysis of a mixed elliptic problem with flux and convective boundary conditions to obtain a discrete solution of nonconstant sign, Numerical Methods for Partial Differential Equations, vol.6, issue.3, pp.355-369, 1999. ,
DOI : 10.1007/BF02760180
A commutative diagram among discrete and continuous boundary optimal control problems, Adv. Diff. Eq. Control Processes, vol.14, pp.23-54, 2014. ,
Optimal control of partial differential equations. Theory, methods and applications, Providence, 2010. ,
Finite element method for constrained optimal control problems governed by nonlinear elliptic PDEs, Mathematical Control and Related Fields, vol.2, issue.2, pp.183-194, 2012. ,
DOI : 10.3934/mcrf.2012.2.183
URL : http://www.aimsciences.org/journals/doIpChk.jsp?paperID=7400&mode=full
The existence results for obstacle optimal control problems, Applied Mathematics and Computation, vol.214, issue.2, pp.451-456, 2009. ,
DOI : 10.1016/j.amc.2009.04.006
