Abstract : A least-squares method is developed for estimating parameters in a size-structured population model with distributed states-at-birth from field data. First and second order finite difference schemes for approximating the nonlinear-nonlocal partial differential equation model are utilized in the least-squares problem. Convergence results for the computed parameters are established. Numerical results demonstrating the efficiency of the technique are provided.
https://hal.inria.fr/hal-01626901
Contributor : Hal Ifip <>
Submitted on : Tuesday, October 31, 2017 - 2:40:49 PM Last modification on : Tuesday, October 31, 2017 - 2:44:58 PM Long-term archiving on: : Thursday, February 1, 2018 - 1:32:52 PM
Azmy Ackleh, Xinyu Li, Baoling Ma. Parameter Estimation in a Size-Structured Population Model with Distributed States-at-Birth. 27th IFIP Conference on System Modeling and Optimization (CSMO), Jun 2015, Sophia Antipolis, France. pp.43-57, ⟨10.1007/978-3-319-55795-3_3⟩. ⟨hal-01626901⟩
