Optimization of Engineering Processes Including Heating in Time-Dependent Domains - Archive ouverte HAL Access content directly
Conference Papers Year : 2016
(1) , (2) , (1) , (1) , (1) , (1)
1
2
Alfred Schmidt
  • Function : Author
  • PersonId : 1021976
Mischa Jahn
  • Function : Author
  • PersonId : 1021978
Andreas Luttmann
  • Function : Author
  • PersonId : 1021979
Carsten Niebuhr
  • Function : Author
  • PersonId : 1021980
Jost Vehmeyer
  • Function : Author
  • PersonId : 1021981
We present two models for engineering processes, where thermal effects and time-dependent domains play an important role. Typically, the parabolic heat equation is coupled with other equations. Challenges for the optimization of such systems are presented.The first model describes a milling process, where material is removed and heat is produced by the cutting, leading to thermomechanical distortion. Goal is the minimization of these distortions.The second model describes the melting and solidification of metal, where the geometry is a result of free-surface flow of the liquid and the microstructure of the re-solidified material is important for the quality of the produced preform.
447583_1_En_43_Chapter.pdf (2.21 Mo) Télécharger le fichier
Dates and versions
hal-01626905 , version 1 (31-10-2017)
Attribution - CC BY 4.0
Identifiers
Cite
Alfred Schmidt, Eberhard Bänsch, Mischa Jahn, Andreas Luttmann, Carsten Niebuhr, et al.. Optimization of Engineering Processes Including Heating in Time-Dependent Domains. 27th IFIP Conference on System Modeling and Optimization (CSMO), Jun 2015, Sophia Antipolis, France. pp.452-461, ⟨10.1007/978-3-319-55795-3_43⟩. ⟨hal-01626905⟩
123 View
76 Download
Share
