Nonlinear parameter estimation, 1974. ,
Relative curvature measures of nonlinearity, Journal of the Royal Statistical Society Ser. B, vol.42, pp.1-25, 1980. ,
Nonlinear regression analysis and its applications Wiley series in probability and mathematical statistics. Applied probability and statistics, 1988. ,
Covariance Matrices for Parameter Estimates of Constrained Parameter Estimation Problems, SIAM Journal on Matrix Analysis and Applications, vol.29, issue.2, pp.626-642, 2007. ,
DOI : 10.1137/040617893
Bayesian Inference in Statistical Analysis, 1973. ,
DOI : 10.1002/9781118033197
Accelerating Asymptotically Exact MCMC for Computationally Intensive Models via Local Approximations, Journal of the American Statistical Association, vol.50, issue.516, 2015. ,
DOI : 10.1137/040615201
A Note on Parameter-Effects Curvature, Journal of the American Statistical Association, vol.19, issue.392, pp.872-878, 1985. ,
DOI : 10.2307/2346325
Theoretical statistics, 1974. ,
DOI : 10.1007/978-1-4899-2887-0
Confidence regions for the parameters of a nonlinear regression model, Mimeograph Series No. 1077, pp.633-643, 1976. ,
DRAM: Efficient adaptive MCMC, Statistics and Computing, vol.18, issue.2, pp.339-354, 2006. ,
DOI : 10.1093/biomet/88.4.1035
URL : http://www.math.helsinki.fi/reports/Preprint374.pdf
Accounting for Intrinsic Nonlinearity in Nonlinear Regression Parameter Inference Regions, The Annals of Statistics, vol.10, issue.2, pp.386-393, 1982. ,
DOI : 10.1214/aos/1176345780
URL : http://doi.org/10.1214/aos/1176345780
Asymptotic Properties of Non-Linear Least Squares Estimators, The Annals of Mathematical Statistics, vol.40, issue.2, pp.633-643, 1969. ,
DOI : 10.1214/aoms/1177697731
URL : http://doi.org/10.1214/aoms/1177697731
SECOND-ORDER SENSITIVITY ANALYSIS OF PARAMETER ESTIMATION PROBLEMS, International Journal for Uncertainty Quantification, vol.5, issue.3, pp.209-231, 2015. ,
DOI : 10.1615/Int.J.UncertaintyQuantification.2015010312
Confidence regions of estimated parameters for ecological systems, Ecological Modelling, vol.165, issue.2-3, pp.127-146, 2003. ,
DOI : 10.1016/S0304-3800(03)00068-1
Teaching about approximate confidence regions based on maximum likelihood estimation, The American Statistician, vol.49, issue.1, pp.48-53, 1995. ,
DOI : 10.1080/00031305.1995.10476112
Measures of agreement between computation and experiment: Validation metrics, Journal of Computational Physics, vol.217, issue.1, pp.5-36, 2006. ,
DOI : 10.1016/j.jcp.2006.03.037
Nonlinear statistical models, 1994. ,
DOI : 10.1007/978-94-017-2450-0
Confidence regions in nonlinear regression models, Applications of Mathematics, vol.37, issue.1, pp.29-39, 1992. ,
Design for model parameter uncertainty using nonlinear confidence regions, AIChE Journal, vol.72, issue.8, pp.1794-1804, 2001. ,
DOI : 10.1002/0471725315
Nonlinear regression, 1989. ,
Confidence region estimation techniques for nonlinear regression in groundwater flow: Three case studies, Water Resources Research, vol.307, issue.3, 2007. ,
DOI : 10.1016/0016-0032(79)90026-7
