Chloroform aerobic cometabolism by butane-growing Rhodococcus aetherovorans BCP1 in continuous-flow biofilm reactors, Bioprocess and Biosystems Engineering, vol.29, issue.40, pp.667-681, 2012. ,
DOI : 10.1111/j.1745-6584.1991.tb00516.x
Application of the growth substrate pulsed feeding technique to a process of chloroform aerobic cometabolism in a continuous-flow sand-filled reactor, Process Biochemistry, vol.47, issue.11, pp.1656-1664, 2012. ,
DOI : 10.1016/j.procbio.2011.08.019
Numerical Parameters Estimation in Models of Pollutant Transport with Chemical Reaction, System Modeling and Optimization ,
DOI : 10.1007/978-3-642-36062-6_55
URL : https://hal.archives-ouvertes.fr/hal-01347583
Olive mill wastewater valorisation through phenolic compounds adsorption in a continuous flow column, Chemical Engineering Journal, vol.283, pp.293-303, 2016. ,
DOI : 10.1016/j.cej.2015.07.048
Practical Methods of Optimization, 2013. ,
DOI : 10.1002/9781118723203
Numerical Optimization, 2006. ,
DOI : 10.1007/b98874
??ber die Verwendung des Morozovschen Diskrepanz Prinzips bei Tikhonov Regularisierung zur L??sung nichtlinearer inkorrekt gestellter Probleme, Computing, vol.5, issue.1, pp.45-60, 1993. ,
DOI : 10.1007/978-1-4612-5280-1
Parameter Identification by Iterative Constrained Regularization, Journal of Physics: Conference Series, vol.657, p.2016 ,
DOI : 10.1088/1742-6596/657/1/012002
URL : http://iopscience.iop.org/article/10.1088/1742-6596/657/1/012002/pdf
Hansen Semi-convergence and relaxation parameters for a class of SIRT algorithms, Electronic Transactions on Numerical Analysis. V, vol.37, pp.321-336, 2010. ,
