A Contact Model for Piezoelectric Beams - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We consider a mathematical model which describes the equilibrium of an electro-elastic beam in contact with an electrically conductive foundation. The model is constructed by coupling the beam equation with the one dimensional piezoelectricity system obtained in [13]. We state the unique weak solvability of the model as well as the continuous dependence of the weak solution with respect to the data. We also introduce a discrete scheme for which we perform the numerical analysis, including convergence and error estimates results. Finally, we present numerical simulations in the study of a test problem.
447583_1_En_42_Chapter.pdf (299.96 Ko) Télécharger le fichier
hal-01626911 , version 1 (31-10-2017)
Paternité
Á. Rodríguez-Arós, M. T. Cao-Rial, M. Sofonea. A Contact Model for Piezoelectric Beams. 27th IFIP Conference on System Modeling and Optimization (CSMO), Jun 2015, Sophia Antipolis, France. pp.442-451, ⟨10.1007/978-3-319-55795-3_42⟩. ⟨hal-01626911⟩
124 Consultations
112 Téléchargements
