Fast image recovery using variable splitting and constrained optimization Gaussian blur out-of-focus blur NL=0 tol ? Method MSE Obj Time MSE Obj Time MSE Obj Time MSE Obj Time, IEEE Trans. Image Process ,
A Fast Iterative Shrinkage-Thresholding Algorithm for Linear Inverse Problems, SIAM Journal on Imaging Sciences, vol.2, issue.1, pp.183-202, 2009. ,
DOI : 10.1137/080716542
URL : http://ie.technion.ac.il/%7Ebecka/papers/finalicassp2009.pdf
NESTA: A Fast and Accurate First-Order Method for Sparse Recovery, SIAM Journal on Imaging Sciences, vol.4, issue.1, pp.1-39, 2011. ,
DOI : 10.1137/090756855
URL : http://www.acm.caltech.edu/~emmanuel/papers/NESTA.pdf
Projected Newton Methods for Optimization Problems with Simple Constraints, SIAM Journal on Control and Optimization, vol.20, issue.2, pp.221-245, 1982. ,
DOI : 10.1137/0320018
URL : http://www-mit.mit.edu/dimitrib/www/ProjectedNewton.pdf
A New TwIST: Two-Step Iterative Shrinkage/Thresholding Algorithms for Image Restoration, IEEE Transactions on Image Processing, vol.16, issue.12, p.2992173004, 2007. ,
DOI : 10.1109/TIP.2007.909319
Gradient Projection for Sparse Reconstruction: Application to Compressed Sensing and Other Inverse Problems, IEEE Journal of Selected Topics in Signal Processing, vol.1, issue.4, pp.586-597, 2007. ,
DOI : 10.1109/JSTSP.2007.910281
URL : http://www.lx.it.pt/~mtf/GPSR/Figueiredo_Nowak_Wright_twocolumn.pdf
The Split Bregman Method for L1-Regularized Problems, SIAM Journal on Imaging Sciences, vol.2, issue.2, pp.323-343, 2009. ,
DOI : 10.1137/080725891
High-order methods for basis pursuit, 2010. ,
Fixed-Point Continuation for $\ell_1$-Minimization: Methodology and Convergence, SIAM Journal on Optimization, vol.19, issue.3, pp.1107-1130, 2008. ,
DOI : 10.1137/070698920
A Modified Newton Projection Method for $$\ell _1$$ ??? 1 -Regularized Least Squares Image Deblurring, Journal of Mathematical Imaging and Vision, vol.40, issue.7, pp.195-208, 2015. ,
DOI : 10.1137/070703983
Optimization for Machine Learning, chapter Projected Newton-type Methods in Machine Learning, 2011. ,
Computational Methods for Inverse Problems, SIAM, 2002. ,
DOI : 10.1137/1.9780898717570
Sparse reconstruction by separable approximation, IEEE Trans. Signal Process, vol.57, issue.7, p.2479172493, 2009. ,
DOI : 10.1109/icassp.2008.4518374
URL : http://www.cs.wisc.edu/~swright/papers/Wright_Nowak_Figueiredo_2007_submitted.pdf
