Abstract : The problem is that of sequential probability forecasting for finite-valued time series. The
data is generated by an unknown probability distribution over the space of all one-way infinite
sequences. It is known that this measure belongs to a given set C, but the latter is completely
arbitrary (uncountably infinite, without any structure given). The performance is measured with
asymptotic average log loss. In this work it is shown that the minimax asymptotic performance
is always attainable, and it is attained by a convex combination of a countably many measures
from the set C (a Bayesian mixture). This was previously only known for the case when the
best achievable asymptotic error is 0. This also contrasts previous results that show that in the
non-realizable case all Bayesian mixtures may be suboptimal, while there is a predictor that
achieves the optimal performance.
