Feedback control of multibody systems with joint clearance and dynamic backlash: a tutorial
The problem of feedback control of mechanisms with joint clearance is analysed. Various control strategies are reviewed: impactless trajectories with persistent contact, control through collisions, the stabilization of equilibrium points, and trajectory tracking control. This article sets a general control framework, brings some preliminary answers and leaves some problems open, which are mentionned all through the article and in the conclusions.
