Implicit Euler numerical scheme and chattering-free implementation of sliding mode systems, Systems & Control Letters, vol.59, issue.5, pp.284-293, 2010. ,
DOI : 10.1016/j.sysconle.2010.03.002
URL : https://hal.archives-ouvertes.fr/inria-00423576
Chattering-free digital sliding-mode control with state observer and disturbance rejection. Automatic Control, IEEE Transactions on, vol.57, issue.5, pp.1087-1101, 2012. ,
DOI : 10.1109/tac.2011.2174676
URL : https://hal.archives-ouvertes.fr/inria-00494417
Finite Time Stabilization of Nonlinear Oscillators Subject to dry Friction, Progresses in Nonsmooth Mechanics and Analysis, chapter 24 ,
DOI : 10.1007/0-387-29195-4_24
URL : https://hal.archives-ouvertes.fr/hal-00068295
Differential Inclusions: Set-Valued Maps and Viability Theory. Grundlehren der mathematischen Wissenschaften, 1984. ,
An inertial proximal algorithm with dry friction: finite convergence results. Set-Valued Analysis, pp.1-23, 2006. ,
DOI : 10.1007/s11228-005-0002-4
URL : https://hal.archives-ouvertes.fr/hal-00068884
Convergence order of implicit Euler numerical scheme for maximal monotone differential inclusions, Zeitschrift für angewandte Mathematik und Physik, pp.955-966, 2013. ,
DOI : 10.1137/0729026
Convex Analysis and Monotone Operator Theory in Hilbert Spaces, CMS Books in Mathematics, 2011. ,
DOI : 10.1007/978-3-319-48311-5
URL : https://hal.archives-ouvertes.fr/hal-01517477
Linear Matrix Inequalities in System and Control Theory, Studies in Applied Mathematics. Society for Industrial and Applied Mathematics, 1994. ,
DOI : 10.1137/1.9781611970777
Opérateurs Maximaux Monotones et Semi-groupes de Contractions dans les Espaces de Hilbert. Number 5 in North-Holland mathematics studies, 1973. ,
Well-posedness, stability and invariance results for a class of multivalued Lur???e dynamical systems, Nonlinear Analysis: Theory, Methods & Applications, vol.74, issue.1, pp.195-212, 2011. ,
DOI : 10.1016/j.na.2010.08.034
URL : https://hal.archives-ouvertes.fr/inria-00442081
On the equivalence between complementarity systems, projected systems and differential inclusions, Systems & Control Letters, vol.55, issue.1, pp.45-51, 2006. ,
DOI : 10.1016/j.sysconle.2005.04.015
URL : https://hal.archives-ouvertes.fr/inria-00071475
Linear passive systems and maximal monotone mappings, Mathematical Programming, pp.1-24, 2015. ,
DOI : 10.1137/0131050
URL : https://doi.org/10.1007/s10107-015-0945-7
Evolution equations governed by the sweeping process. Set-Valued Analysis, pp.109-139, 1993. ,
DOI : 10.1007/bf01027688
Analysis and design of integral sliding manifolds for systems with unmatched perturbations. Automatic Control, IEEE Transactions on, vol.51, issue.5, pp.853-858, 2006. ,
Non-convex perturbations of maximal monotone differential inclusions, Israel Journal of Mathematics, vol.12, issue.1-2, pp.1-11, 1983. ,
DOI : 10.1007/978-3-662-11791-0
A new method for variable structure control system design: A linear matrix inequality approach, Automatica, vol.33, issue.11, pp.2089-2092, 1997. ,
DOI : 10.1016/S0005-1098(97)00118-0
An LMI-based switching surface design method for a class of mismatched uncertain systems, IEEE Transactions on Automatic Control, vol.48, issue.9, pp.1634-1638, 2003. ,
DOI : 10.1109/TAC.2003.817007
Discontinuous dynamical systems, IEEE Control Systems Magazine, vol.28, issue.3, pp.36-73, 2008. ,
DOI : 10.1109/MCS.2008.919306
BV solutions of nonconvex sweeping process differential inclusion with perturbation, Journal of Differential Equations, vol.226, issue.1, pp.135-179, 2006. ,
DOI : 10.1016/j.jde.2005.12.005
Differential Equations with Discontinuous Righthand Sides: Control Systems. Mathematics and its Applications, 1988. ,
DOI : 10.1007/978-94-015-7793-9
Euler's Discretization of Single Input Sliding-Mode Control Systems, IEEE Transactions on Automatic Control, vol.52, issue.9, pp.1726-1730, 2007. ,
DOI : 10.1109/TAC.2007.904289
Analysis of Zero-Order Holder Discretization of Two-Dimensional Sliding-Mode Control Systems, IEEE Transactions on Circuits and Systems II: Express Briefs, vol.55, issue.12, pp.1269-1273, 2008. ,
DOI : 10.1109/TCSII.2008.2008069
CVX: Matlab software for disciplined convex programming, version 2.1, 2014. ,
DOI : 10.1007/0-387-30528-9_7
URL : http://www.stanford.edu/~boyd/papers/pdf/disc_cvx_prog.pdf
Lyapunov stability and performance analysis of the implicit discrete sliding mode control. Automatic Control, IEEE Transactions ,
URL : https://hal.archives-ouvertes.fr/hal-01236159
Discrete-time twisting controller without numerical chattering: analysis and experimental results with an implicit method, 53rd IEEE Conference on Decision and Control, pp.129-141, 2016. ,
DOI : 10.1109/CDC.2014.7040071
URL : https://hal.archives-ouvertes.fr/hal-01066689
Experimental results on implicit and explicit time-discretization of equivalent control-based sliding mode control ,
DOI : 10.1049/PBCE102E_ch3.2
URL : https://hal.archives-ouvertes.fr/hal-01238120
Elements of the Theory of Funtions and Functional Analysis, 1957. ,
Convex Functional Analysis. Systems & Control: Foundations & Applications, 2005. ,
Higher-order sliding modes, differentiation and output-feedback control, International Journal of Control, vol.76, issue.9-10, pp.924-941, 2003. ,
DOI : 10.1080/0020717031000099029
Robust output regulation of variable structure systems with multivalued controls, Variable Structure Systems (VSS), 2014 13th International Workshop on, pp.1-6, 2014. ,
Robust output regulation of strongly linear passive systems with multivalued maximally monotone controls. Automatic Control, IEEE Transactions ,
Sliding Mode Control In Engineering. Automation and Control Engineering, 2002. ,
Evolution equations for maximal monotone operators: asymptotic analysis in continuous and discrete time, Journal of Convex Analysis, vol.17, issue.3 4, pp.1113-1163, 2010. ,
Invariant ellipsoid method for minimization of unmatched disturbances effects in sliding mode control, Automatica, vol.47, issue.7, pp.1450-1454, 2011. ,
DOI : 10.1016/j.automatica.2011.02.013
Convex Analysis. Convex Analysis, 1970. ,
Variational Analysis. Die Grundlehren der mathematischen Wissenschaften in Einzeldarstellungen, 2009. ,
Sliding Mode Control and Observation, 2014. ,
DOI : 10.1007/978-0-8176-4893-0
Using SeDuMi 1.02, a MATLAB toolbox for optimization over symmetric cones. Optimization methods and software, pp.625-653, 1999. ,
DOI : 10.1080/10556789908805766
URL : http://www.unimaas.nl/~sturm/papers/guide.ps.gz
Sliding Modes in Control and Optimization. Communications and Control Engineering, 1992. ,
DOI : 10.1007/978-3-642-84379-2
Adaptive Sliding Mode Control, Advances in Sliding Mode Control: Concept, Theory and Implementation, pp.21-54, 2013. ,
DOI : 10.1007/978-3-642-36986-5_2
Integral sliding mode in systems operating under uncertainty conditions, Proceedings of 35th IEEE Conference on Decision and Control, pp.4591-4596, 1996. ,
DOI : 10.1109/CDC.1996.577594
Sliding mode control on electro-mechanical systems, Mathematical Problems in Engineering, vol.8, issue.4-5, 2009. ,
DOI : 10.1080/10241230306724
URL : http://doi.org/10.1080/10241230306724
Experimental Comparisons Between Implicit and Explicit Implementations of Discrete-Time Sliding Mode Controllers: Toward Input and Output Chattering Suppression, IEEE Transactions on Control Systems Technology, vol.23, issue.5, pp.2071-2075, 2015. ,
DOI : 10.1109/TCST.2015.2396473
URL : https://hal.archives-ouvertes.fr/hal-01625866
A control engineer's guide to sliding mode control, IEEE Transactions on Control Systems Technology, vol.7, issue.3, pp.328-342, 1999. ,
DOI : 10.1109/87.761053
