I. Akturk, K. Khatamifard, and U. R. Karpuzcu, On quantification of accuracy loss in approximate computing, Proc. of WDDD, 2015.
W. Baek and T. M. Chilimbi, Green: A Framework for Supporting Energy-Conscious Programming using Controlled Approximation, Proc. of PLDI, 2010.
C. Bienia, S. Kumar, J. P. Singh, and K. Li, The PARSEC benchmark suite, Proceedings of the 17th international conference on Parallel architectures and compilation techniques, PACT '08, 2008.
DOI : 10.1145/1454115.1454128
V. Gupta, D. Mohapatra, S. P. Park, A. Raghunathan, and K. Roy, IMPACT: IMPrecise adders for low-power approximate computing, IEEE/ACM International Symposium on Low Power Electronics and Design, 2011.
DOI : 10.1109/ISLPED.2011.5993675
Z. Kedem, V. J. Mooney, K. K. Muntimadugu, K. V. Palem, A. Devarasetty et al., Optimizing energy to minimize errors in dataflow graphs using approximate adders, Proceedings of the 2010 international conference on Compilers, architectures and synthesis for embedded systems, CASES '10, 2010.
DOI : 10.1145/1878921.1878948
W. Lin, J. Kuo, and C. C. , Perceptual visual quality metrics: A survey, Journal of Visual Communication and Image Representation, vol.22, issue.4, 2011.
DOI : 10.1016/j.jvcir.2011.01.005
J. Liu, B. Jaiyen, R. Veras, and O. Mutlu, RAIDR, Proc. of ISCA, 2012.
DOI : 10.1145/2366231.2337161
S. Misailovic, S. Sidiroglou, H. Hoffmann, and M. Rinard, Quality of service profiling, Proceedings of the 32nd ACM/IEEE International Conference on Software Engineering, ICSE '10, 2010.
DOI : 10.1145/1806799.1806808
URL : http://people.csail.mit.edu/stelios/papers/qos_profiling.pdf
S. Mittal, A Survey of Techniques for Approximate Computing, ACM Computing Surveys, vol.48, issue.4, 2016.
DOI : 10.1109/DAC.2014.6881426
O. Neugebauer, P. Libuschewski, M. Engel, H. Müller, and P. Marwedel, Plasmon-based Virus Detection on Heterogeneous Embedded Systems, Proceedings of the 18th International Workshop on Software and Compilers for Embedded Systems, SCOPES '15, 2015.
DOI : 10.1007/s11468-009-9111-5
L. Renganarayana, V. Srinivasan, R. Nair, and D. Prener, Programming with relaxed synchronization, Proceedings of the 2012 ACM workshop on Relaxing synchronization for multicore and manycore scalability, RACES '12, 2012.
DOI : 10.1145/2414729.2414737
A. Sampson, W. Dietl, E. Fortuna, D. Gnanapragasam, and L. Ceze, EnerJ: Approximate Data Types for Safe and General Low-power Computation, Proc. of PLDI, 2011.
S. Sidiroglou, S. Misailovic, H. Hoffmann, and M. Rinard, Managing performance vs. accuracy trade-offs with loop perforation, Proceedings of the 19th ACM SIGSOFT symposium and the 13th European conference on Foundations of software engineering, SIGSOFT/FSE '11, 2011.
DOI : 10.1145/2025113.2025133
Z. Wang and A. C. Bovik, A universal image quality index, Signal Processing Letters IEEE, vol.9, issue.3, 2002.
Z. Wang, A. C. Bovik, H. R. Sheikh, and E. P. Simoncelli, Image Quality Assessment: From Error Visibility to Structural Similarity, IEEE Transactions on Image Processing, vol.13, issue.4, 2004.
DOI : 10.1109/TIP.2003.819861
URL : http://www.cns.nyu.edu/~zwang/files/papers/ssim.pdf
. Xiph, Org Foundation, 2016.
