Goncalves Smart Manufacturing Systems Dynamic Simulation for MAS-Based Data Acquisition and Pre-processing in Manufacturing Using V, p.125 ,
135 Hessamedin Bayanifar and Hermann Kühnle Features Extraction from CAD as a Basis for Assembly Process Planning, p.144 ,
Active Barriers Considering Different Scenarios of Faults in Modern Production Systems, p.154 ,
Sensorial Systems Image Analysis as a Tool to Age Estimations in Fishes: An Approach Using Blue Whiting on, 167 Patrícia Gonçalves, Vitor Vaz da Silva, Alberto G. Murta, António Ávila de Melo, and Henrique N. Cabral Signal Processing Techniques for Accurate Screening of Wrist Fractures, p.175 ,
Lyuba Alboul, and Amaka Offiah TRACEO3D Ray Tracing Model for Underwater Noise Predictions, p.183 ,
Rodríguez Feature Transformation Based on Stacked Sparse Autoencoders for Sleep Stage Classification, Shirin Najdi, p.203 ,
211 Ondrej Kachman and Marcel Balaz Upper Bounds Prediction of the Execution Time of Programs Running on ARM Cortex-A Systems 220 Irina Fedotova, Bernd Krause, and Eduard Siemens Energy: Management Assessment of Ancillary Service Demand Response and Time of Use in a Market-Based Power System Through a Stochastic Security Constrained Unit, Commitment . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 233 Saber Talari ,
Mendes Impact of Distributed Generation on the Thermal Ageing of Low Voltage Distribution Cables, 251 Gergely Márk Csányi, Zoltán Ádám Tamus, and Árpád Varga A Hybrid Anti-islanding Method for Inverter-Based Distributed Generation, p.259 ,
Catalão Energy: Optimization A New DG Planning Approach to Maximize Renewable -Based DG Penetration Level and Minimize Annual Loss Catalão Stochastic Optimization for the Daily Joint Operation of Wind, p.277 ,
Catalão Distributed Infrastructure RELOAD/CoAP P2P Overlays for Network Coding Based Constrained Environments, p.307 ,
Abouzar Estebsari, Enrico Pons, and Andrea Acquaviva MAP Estimator for Target Tracking in Wireless Sensor Networks for Unknown Transmit, PVInGrid: A Distributed Infrastructure for Evaluating the Integration of Photovoltaic Systems in 325 Slavisa Tomic Tuba, and Nebojsa Bacanin Solar Energy Performance Assessment of Tank Fluid Purging and Night Cooling as Overheating Prevention Techniques for Photovoltaic-Thermal ,
Joyce Stochastic Optimal Operation of Concentrating Solar Power Plants Based on Conditional Value-at-Risk, p.348 ,
Cristina Inês Camus, and Stanimir Stoyanov Valtchev Electrical Machines A Generalized Geometric Programming Sub-problem of Transformer Design Optimization, 373 Tamás Orosz, Tamás Nagy, and Zoltán Ádám Tamus ,
398 Pedro Melo and Rui Esteves Araújo Power Electronics Comparative Analysis of qZS-Based Bidirectional DC-DC Converter for Storage Energy Application ,
Vinnikov Electronics Design Methodology for an All CMOS Bandgap Voltage Reference Circuit, 439 Ricardo Madeira and Nuno Paulino ,
Vieira Microneedle Based ECG ? Glucose Painless MEMS Sensor with Analog Front End for Portable Devices, p.463 ,
Dian Li, and João Goes Crystalline Silicon PV Module Under Effect of Shading Simulation of the Hot-Spot Condition, p.479 ,
