Integrated Model Considering Effects of Zero Injection Buses and Conventional Measurements on Optimal PMU Placement, IEEE Transactions on Smart Grid, in press ,
Optimal Allocation of PMUs in the Presence of Conventional Measurements Considering Contingencies, IEEE Transactions on Power Delivery ,
DOI : 10.1109/TPWRD.2016.2524658
Optimal phasor measurement unit placement for numerical observability in the presence of conventional measurements using semi-definite programming, IET Generation, Transmission & Distribution, vol.9, issue.15, pp.2427-2436, 1119. ,
DOI : 10.1049/iet-gtd.2015.0662
Taxonomy of PMU Placement Methodologies, IEEE Transactions on Power Systems, vol.27, issue.2, pp.1070-1077, 2012. ,
DOI : 10.1109/TPWRS.2011.2179816
An optimal PMU placement method for power system observability under various contingencies, International Transactions on Electrical Energy Systems, vol.1, issue.1, pp.589-606, 2015. ,
DOI : 10.1016/j.epsr.2011.09.010
State estimation and observability analysis for phasor measurement unit measured systems, IET Generation, Transmission & Distribution, vol.6, issue.9, pp.902-913, 2012. ,
DOI : 10.1049/iet-gtd.2011.0492
Iot-based smart cities: A survey, 2016 IEEE 16th International Conference on Environment and Electrical Engineering (EEEIC), pp.1-6 ,
DOI : 10.1109/EEEIC.2016.7555867
A novel multi-time-scale modeling for electric power demand forecasting: From short-term to medium-term horizon, Electric Power Systems Research, vol.142, pp.58-73, 2017. ,
Overview of the Security and Privacy Issues in Smart Grids Smart Grids: Security and Privacy Issues, pp.1-16, 2017. ,
From Demand Response in Smart Grid Toward Integrated Demand Response in Smart Energy Hub, IEEE Transactions on Smart Grid, vol.7, issue.2, pp.650-658, 2016. ,
DOI : 10.1109/TSG.2015.2464374
Contingency-Constrained PMU Placement in Power Networks, IEEE Transactions on Power Systems, vol.25, issue.1, pp.516-523, 2010. ,
DOI : 10.1109/TPWRS.2009.2036470
Observability analysis and measurement placement for systems with PMUs, IEEE Power Syst. Conf. Expo, pp.943-946, 2004. ,
Placement of PMUs to Enable Bad Data Detection in State Estimation, 14. Generalized Algebraic Modeling Systems (GAMS), [Online] Available, pp.1608-1615, 2006. ,
DOI : 10.1109/TPWRS.2006.881149
