Efficient Fuzzy Controller to Increase Soybean Productivity - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Bruno S. Miranda
  • Fonction : Auteur
  • PersonId : 1022203
Gian M. Meira
  • Fonction : Auteur
  • PersonId : 1022204
Sidney J. Montebeller
  • Fonction : Auteur
  • PersonId : 1022205
Edinei P. Legaspe
  • Fonction : Auteur
  • PersonId : 1022206
Joel R. Pinto
  • Fonction : Auteur
  • PersonId : 1022207
Soybean production has expanded intensively in South America over the last decades. As the second leading worldwide soybean producer, Brazil has in prospect to increase market share through production growth in soybean areas. Therefore, soybean fields ought to encompass a sizeable region among different types of soil and climate conditions, and so advanced irrigation methods should be advantageous. This present work aims to optimize soybean production through an irrigation system control based on environmental and plant requirements. It was developed an embedded fuzzy controller that is able to process soil moisture, air moisture, temperature, soil type and soybean growth stages and it returns the ideal amount of water. Also, to accomplish the data acquisition, a multiparameter sensor device establishes remote connection and provides continuous in-field measurement. The efficiency of the fuzzy controller and the monitoring unit was verified through simulations, and so, results reached the expected model.
448071_1_En_4_Chapter.pdf (663.05 Ko) Télécharger le fichier
hal-01629567 , version 1 (06-11-2017)
Paternité
Bruno S. Miranda, Gian M. Meira, Sidney J. Montebeller, Edinei P. Legaspe, Joel R. Pinto, et al.. Efficient Fuzzy Controller to Increase Soybean Productivity. 8th Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), May 2017, Costa de Caparica, Portugal. pp.47-54, ⟨10.1007/978-3-319-56077-9_4⟩. ⟨hal-01629567⟩
71 Consultations
70 Téléchargements
