Data Fusion of Georeferenced Events for Detection of Hazardous Areas - Archive ouverte HAL Access content directly
Conference Papers Year : 2017
(1) , (2) , (2) , (2)
1
2
When dealing with events in moving vehicles, which can occur over widespread areas, it is difficult to identify sources that do not derive from material fatigue, but from situations that occur in specific spots. Considering a railway system, problems could occur in trains, not because of train’s equipment failure, but because the train is crossing a specific location. This paper presents a new smart system being developed that is able to generate geo-located sensor-data; transmit it for smart processing and fusing to the inference engine being built to correlate the data, and drill-down the information. Using a statistical approach within the inference engine, it is possible to combine results collected over long periods of time in a “heat-map” of frequent fault areas, mapping faulty events to detect hazardous locations using georeferenced sensor data, collected from several trains that will be integrated in these maps to infer high probability risk areas.
448071_1_En_7_Chapter.pdf (338.68 Ko) Télécharger le fichier
Dates and versions
hal-01629570 , version 1 (06-11-2017)
Attribution - CC BY 4.0
Identifiers
Cite
Sérgio Onofre, João Gomes, João Paulo Pimentão, Pedro Alexandre Sousa. Data Fusion of Georeferenced Events for Detection of Hazardous Areas. 8th Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), May 2017, Costa de Caparica, Portugal. pp.81-89, ⟨10.1007/978-3-319-56077-9_7⟩. ⟨hal-01629570⟩
38 View
66 Download
Share
