MAP Estimator for Target Tracking in Wireless Sensor Networks for Unknown Transmit Power - Archive ouverte HAL Access content directly
Conference Papers Year : 2017
(1, 2) , (3, 4) , (2, 5) , (6) , (6)
1
2
3
4
5
6
This paper addresses the target tracking problem, by extracting received signal strength (RSS) and angle of arrival (AoA) information from the received radio signal, in the case where the target transmit power is considered unknown. By combining the radio observations with prior knowledge given by the target transition state model, we apply the maximum a posteriori (MAP) criterion to the marginal posterior distribution function (PDF). However, the derived MAP estimator cannot be solved directly, so we tightly approximate it for small noise power. The target state estimate is then easily obtained at any time step by employing a recursive approach, typical for Bayesian methods. Our simulations confirm the effectiveness of the proposed algorithm, offering good estimation accuracy in all considered scenarios.
448071_1_En_32_Chapter.pdf (776.84 Ko) Télécharger le fichier
Dates and versions
hal-01629571 , version 1 (06-11-2017)
Attribution - CC BY 4.0
Identifiers
Cite
Slavisa Tomic, Marko Beko, Rui Dinis, Milan Tuba, Nebojsa Bacanin. MAP Estimator for Target Tracking in Wireless Sensor Networks for Unknown Transmit Power. 8th Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), May 2017, Costa de Caparica, Portugal. pp.325-334, ⟨10.1007/978-3-319-56077-9_32⟩. ⟨hal-01629571⟩
142 View
149 Download
Share
