Fault development on water ingress in damaged underground Low Voltage cables with plastic insulation, 2015 IEEE Electrical Insulation Conference (EIC), pp.309-312, 2015. ,
DOI : 10.1109/ICACACT.2014.7223568
Thermal behaviour of low voltage cables in smart grid — Related environments, IEEE PES Innovative Smart Grid Technologies, Europe, pp.1-6, 2014. ,
DOI : 10.1109/ISGTEurope.2014.7028736
A method to place meters in active low voltage distribution networks using BPSO algorithm, 2016 Power Systems Computation Conference (PSCC), pp.1-7, 2016. ,
DOI : 10.1109/PSCC.2016.7540873
Fast and revenue-oriented protection of radial LV cables with smart battery operation, 2013 IEEE Computational Intelligence Applications in Smart Grid (CIASG), pp.107-114, 2013. ,
DOI : 10.1109/CIASG.2013.6611506
Overloading protection of future low voltage distribution networks, 2011 IEEE Trondheim PowerTech, pp.1-6, 2011. ,
DOI : 10.1109/PTC.2011.6019166
Predicting the technical impacts of high levels of small-scale embedded generators on low-voltage networks, IET Renewable Power Generation, vol.2, issue.4, pp.249-262, 2008. ,
DOI : 10.1049/iet-rpg:20080012
Long-term performance of poly(vinyl chloride) cables. Part 1: Mechanical and electrical performances, Polymer Degradation and Stability, vol.92, issue.4, pp.617-629, 2007. ,
DOI : 10.1016/j.polymdegradstab.2007.01.005
Characterization of dielectric materials by the extension of voltage response method, Journal of Physics: Conference Series, vol.646, issue.1, pp.12043-2015 ,
DOI : 10.1088/1742-6596/646/1/012043
Investigation of dielectric properties of cable insulation by the extended voltage response method, 2016 Conference on Diagnostics in Electrical Engineering (Diagnostika), pp.1-4, 2016. ,
DOI : 10.1109/DIAGNOSTIKA.2016.7736476
Proposed fundamental characteristics describing dielectric processes in dielectrics, Periodica Polytechnica, Electrical Engineering, vol.15, issue.4, pp.305-322, 1971. ,
Measuring voltage response: a non-destructive diagnostic test method HV of insulation, IEE Proceedings, pp.249-252, 1999. ,
DOI : 10.1049/ip-smt:19990651
Effect of dioctyl phthalate (DOP) plasticizing agent on the dielectric properties of PVC insulation, 2016 Conference on Diagnostics in Electrical Engineering (Diagnostika), pp.1-4, 2016. ,
DOI : 10.1109/DIAGNOSTIKA.2016.7736481
Dielectrics in electric fields, 2003. ,
DOI : 10.1201/9780203912270
Condition assessment of pvc insulated low voltage cables by voltage response method, Int. Conf. on Condition Monitoring and Diagnosis, pp.721-724, 2010. ,
