Descent via (3, 3)-isogeny on Jacobians of genus 2 curves, Acta Arith, pp.201-223, 2014. ,
Endomorphism rings in cryptography, 2011. ,
Isogeny graphs of ordinary abelian varieties, Research in Number Theory, vol.2012, issue.273, 2017. ,
DOI : 10.1090/S0025-5718-2010-02373-7
Complex abelian varieties, Fundamental Principles of Mathematical Sciences], vol.302, 2004. ,
DOI : 10.1007/978-3-662-06307-1
Computing functions on Jacobians and their quotients, LMS Journal of Computation and Mathematics, vol.2, issue.01, pp.555-577, 2015. ,
DOI : 10.1007/978-3-662-03338-8
URL : https://hal.archives-ouvertes.fr/hal-01088933
Curves of genus two over fields of even characteristic, Mathematische Zeitschrift, vol.159, issue.1, pp.177-201, 2005. ,
DOI : 10.1007/s00209-004-0750-0
Applications des fonctions theta a la cryptographie sur courbes hyperelliptiques, 2011. ,
Field of moduli and field of definition for curves of genus 2, Computational Aspects of Algebraic Curves, pp.71-83, 2005. ,
DOI : 10.1142/9789812701640_0006
Computing (, )-isogenies in polynomial time on jacobians of genus 2 curves, http://eprint.iacr.org Towards quantum-resistant cryptosystems from supersingular elliptic curve isogenies, J. Mathematical Cryptology, vol.143, issue.8 3, pp.209-247, 2011. ,
On isogenous principally polarized abelian surfaces, Contemp. Math, vol.465, pp.51-69, 2008. ,
DOI : 10.1090/conm/465/09100
URL : http://arxiv.org/abs/0710.1298
Weber's formula for the bitangents of a smooth plane quartic, https://arxiv.org/abs/1612, p.2049, 2016. ,
Descent via (5, 5)-isogeny on Jacobians of genus 2 curves, J. Number Theory, vol.153, pp.270-282, 2015. ,
Isogeny Volcanoes and the SEA Algorithm, Lecture Notes in Comput. Sci, vol.2369, pp.276-291, 2002. ,
DOI : 10.1007/3-540-45455-1_23
URL : ftp://lix.polytechnique.fr/pub/submissions/morain/Preprints/LIX:RR:00:05:volcanoes.ps.Z
Theta functions, Grundlehren der mathematischen Wissenschaf-ten, 1972. ,
On graphs of isogenies of principally polarizable abelian surfaces and the discrete logarithm problem, p.522, 2015. ,
Endomorphism rings of elliptic curves over finite fields, 1996. ,
Improved crt algorithm for class polynomials in genus 2, IACR Cryptology ePrint Archive, vol.2012, p.443, 2012. ,
Computing isogenies between abelian varieties, Compos. Math, vol.148, issue.5, pp.1483-1515, 2012. ,
Abelian varieties Arithmetic geometry, pp.103-150, 1984. ,
A quasi-linear time algorithm for computing modular polynomials in dimension 2, LMS Journal of Computation and Mathematics, vol.18, pp.603-632, 2015. ,
Modular polynomials on Hilbert surfaces, working paper or preprint, 2017. ,
On the equations defining abelian varieties. I, Invent, Math, vol.1, pp.287-354, 1966. ,
Tata lectures on theta ii. jacobian theta functions and differential equations, with the collaboration of c. musili, m. nori, e. previato, m. stillman and h. umemura, Progress in Mathematics, vol.43, 1984. ,
De transformatione integralium Abelianorum primi ordinis commentatio, J. Reine Angew. Math, vol.16, pp.221-284, 1837. ,
Fonctions thêta et applicationsàapplications`applicationsà la cryptologie, 2010. ,
Isogenies and the discrete logarithm problem in jacobians of genus 3 hyperelliptic curves, J. Cryptology, vol.22, issue.4, pp.505-529, 2009. ,
Isogénies entre courbes elliptiques, C. R. Acad. Sci. Paris Sér. A-B, vol.273, pp.238-241, 1971. ,
