Foundations of Dependent Interoperability - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2017
Full-spectrum dependent types promise to enable the development of correct-by-construction software. However, even certified software needs to interact with simply-typed or untyped programs, be it to perform system calls, or to use legacy libraries. Trading static guarantees for runtime checks, the dependent interoperability framework provides a mechanism by which simply-typed values can safely be coerced to dependent types and, conversely, dependently-typed programs can defensively be exported to a simply-typed application. In this article, we give a semantic account of dependent interoperability. Our presentation relies on and is guided by a pervading notion of type equivalence, whose importance has been emphasized in recent work on homotopy type theory. Specifically, we develop the notion of type-theoretic partial Galois connections as a key foundation for dependent interoperability, which accounts for the partiality of the coercions between types. We explore the applicability of both monotone and antitone type-theoretic Galois connections in the setting of dependent interoperability. A monotone partial Galois connection enforces a translation of dependent types to runtime checks that are both sound and complete with respect to the invariants encoded by dependent types. Conversely, picking an antitone partial Galois connection instead lets us induce weaker, sound conditions that can amount to more efficient runtime checks. Our framework is developed in Coq; it is thus constructive and verified in the strictest sense of the terms. Using our library, users can specify domain-specific partial connections between data structures. Our library then takes care of the (sometimes, heavy) lifting that leads to interoperable programs. It thus becomes possible, as we shall illustrate, to internalize and hand-tune the extraction of dependently-typed programs to interoperable OCaml programs within Coq itself.
main.pdf (225.09 Ko) Télécharger le fichier
hal-01629909 , version 1 (06-11-2017)
hal-01629909 , version 2 (17-12-2017)
  • HAL Id : hal-01629909 , version 1
Pierre-Evariste Dagand, Nicolas Tabareau, Éric Tanter. Foundations of Dependent Interoperability. 2017. ⟨hal-01629909v1⟩
1261 Consultations
1050 Téléchargements
