Forward Error Correction (FEC) Framework Extension to Sliding Window Codes", Transport Area Working Group (TSVWG) draft-roca-tsvwg-fecframev2 (Work in Progress), 2017. ,
Key words for use in RFCs to Indicate Requirement Levels, 1997. ,
DOI : 10.17487/rfc2119
Forward Error Correction (FEC) Framework, RFC, vol.6363, 2011. ,
DOI : 10.17487/rfc6363
URL : http://info.internet.isi.edu/in-notes/pdfrfc/rfc6363.txt.pdf
Session Description Protocol Elements for the Forward Error Correction (FEC) Framework, RFC, vol.6364, 2011. ,
DOI : 10.17487/rfc6364
Two fast implementations of the ???minimal standard??? random number generator, 12.2. Informative References, pp.87-88, 1990. ,
DOI : 10.1145/76372.76379
Random number generators: good ones are hard to find, Communications of the ACM, vol.31, issue.10, pp.1192-1201, 1988. ,
DOI : 10.1145/63039.63042
Numerical Recipies in C; Second Edition, 1992. ,
31 bit pseudo-random number generator, 2005. ,
Low Density Parity Check (LDPC) Staircase and Triangle Forward Error Correction (FEC) Schemes, RFC, vol.5170, 2008. ,
DOI : 10.17487/rfc5170
URL : https://hal.archives-ouvertes.fr/inria-00000147
FLUTE -File Delivery over Unidirectional Transport, RFC, vol.6726, 2012. ,
DOI : 10.17487/rfc3926
URL : https://hal.archives-ouvertes.fr/hal-00749951
Simple Low-Density Parity Check (LDPC) Staircase Forward Error Correction (FEC) Scheme for FECFRAME, RFC, vol.6816, 2012. ,
DOI : 10.17487/rfc6816
URL : https://hal.archives-ouvertes.fr/hal-00781906
Simple Reed-Solomon Forward Error Correction (FEC) Scheme for FECFRAME, RFC, vol.6865, 2013. ,
DOI : 10.17487/rfc6865
URL : https://hal.archives-ouvertes.fr/hal-00799727
Block or Convolutional AL-FEC Codes? A Performance Comparison for Robust Low-Latency Communications", HAL open-archive document,hal-01395937 https, 2016. ,
Less Latency and Better Protection with AL-FEC Sliding Window Codes: a Robust Multimedia CBR Broadcast Case Study, 13th IEEE International Conference on Wireless and Mobile Computing, Networking and Communications (WiMob17), 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01571609
Park-Miller-Carta Pseudo-Random Number Generator, 2008. ,
