Sliding Window Random Linear Code (RLC) Forward Erasure Correction (FEC) Schemes for FECFRAME - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Autre Publication Année : 2018
This document describes two fully-specified FEC Schemes for Sliding Window Random Linear Codes (RLC), one for RLC over GF(2) (binary case), a second one for RLC over GF(2^^8), both of them with the possibility of controlling the code density. They are meant to protect arbitrary media streams along the lines defined by FECFRAME extended to sliding window FEC codes. These sliding window FEC codes rely on an encoding window that slides over the source symbols, generating new repair symbols whenever needed. Compared to block FEC codes, these sliding window FEC codes offer key advantages with real-time flows in terms of reduced FEC-related latency while often providing improved erasure recovery capabilities.
Mots clés
draft-ietf-tsvwg-rlc-fec-scheme-09.pdf (115.07 Ko) Télécharger le fichier
hal-01630089 , version 1 (07-11-2017)
hal-01630089 , version 2 (14-03-2018)
hal-01630089 , version 3 (12-11-2018)
hal-01630089 , version 4 (22-01-2020)
  • HAL Id : hal-01630089 , version 3
Vincent Roca, Belkacem Teibi. Sliding Window Random Linear Code (RLC) Forward Erasure Correction (FEC) Schemes for FECFRAME. 2018, pp.1-25. ⟨hal-01630089v3⟩
310 Consultations
549 Téléchargements
