Reports
Efficient Parallel Solution of the 3D Stationary Boltzmann Transport Equation for Diffusive Problems
Abstract : This paper presents an efficient parallel method for the deterministic solution of the 3D stationary Boltzmann transport equation applied to diffusive problems such as nuclear core criticality computations. Based on standard MultiGroup-Sn-DD discretization schemes, our approach combines a highly efficient nested parallelization strategy with the PDSA parallel acceleration technique applied for the first time to 3D transport problems. These two key ingredients enable us to solve extremely large neutronic problems involving up to 10^(12) degrees of freedom in less than an hour using 64 super-computer nodes.
Complete list of metadata
Cited literature [27 references]  Display  Hide  Download
https://hal.inria.fr/hal-01630208
Contributor : Mathieu Faverge Connect in order to contact the contributor
Submitted on : Friday, December 21, 2018 - 11:28:30 AM
Last modification on : Saturday, June 25, 2022 - 10:38:47 AM
File
RR-9116.pdf
Identifiers
  • HAL Id : hal-01630208, version 2
Collections
Citation
Salli Moustafa, François Févotte, Mathieu Faverge, Laurent Plagne, Pierre Ramet. Efficient Parallel Solution of the 3D Stationary Boltzmann Transport Equation for Diffusive Problems. [Research Report] RR-9116, Inria; EDF Lab. 2017, pp.22. ⟨hal-01630208v2⟩
Share
Metrics
Record views
190
Files downloads
326
