The complete pyramids: Solving the Ancient Mysteries, 2008. ,
Pyramid Construction: New Evidence Discovered in Giza. Stationen: Beiträge zur Kulturgeschichte, 1998. ,
How the great pyramid was built, 2006. ,
Review of particle physics, Chinese Physics C40, p.100001, 2016. ,
Search for Hidden Chambers in the Pyramids, Science, vol.167, issue.3919, pp.832-839, 1970. ,
DOI : 10.1126/science.167.3919.832
Development of an emulsion imaging system for cosmic-ray muon radiography to explore the internal structure of a volcano, Mt. Asama, Nuclear Instruments and Methods in Physics Research Section A: Accelerators, Spectrometers, Detectors and Associated Equipment, vol.575, issue.3 ,
DOI : 10.1016/j.nima.2007.02.104
Development of nuclear emulsion for muography, Annals of Geophysics, vol.60, issue.1, p.112, 2017. ,
The OPERA film: New nuclear emulsion for large-scale, high-precision experiments, Nuclear Instruments and Methods in Physics Research Section A: Accelerators, Spectrometers, Detectors and Associated Equipment, vol.556, issue.1, pp.80-86, 2006. ,
DOI : 10.1016/j.nima.2005.08.109
Development of Nuclear Emulsion Detector for Muon Radiography, Physics Procedia, vol.80, pp.74-77, 2015. ,
DOI : 10.1016/j.phpro.2015.11.084
Detection of on-surface objects with an underground radiography detector system using cosmic-ray muons, Progress of Theoretical and Experimental Physics, vol.2017, issue.5, pp.53-54, 2017. ,
DOI : 10.1093/ptep/ptx061
Performance of a remotely located muon radiography system to identify the inner structure of a nuclear plant, Progress of Theoretical and Experimental Physics, vol.2013, issue.7, pp.73-74, 2013. ,
DOI : 10.1093/ptep/ptt046
The Great Pyramid's Footprint: Results from our, Survey. Aeragram, vol.16, issue.2, pp.8-14, 2015. ,
First report: Video survey of the southern shaft of the queen's chamber in the great pyramid, Annales du Service des Antiquités de l'Egypte, pp.203-216, 2010. ,
The ???Djedi??? Robot Exploration of the Southern Shaft of the Queen's Chamber in the Great Pyramid of Giza, Egypt, Journal of Field Robotics, vol.15, issue.2, pp.323-348, 2013. ,
DOI : 10.7210/jrsj.15.230
Les papyrus de la Mer Rouge 1: Le "journal de Merer, 2017. ,
Imaging the Cheops pyramid, 2011. ,
DOI : 10.1007/978-94-007-2657-4
URL : https://hal.archives-ouvertes.fr/hal-00654495
Microgravimetric and gravity gradient techniques for detection of subsurface cavities, GEOPHYSICS, vol.49, issue.7, pp.1084-1096, 1984. ,
DOI : 10.1190/1.1441723
Non destructive Pyramids investigation, Part 1 and 2, Studies in Egyptian Culture, vol.6, 1987. ,
First demonstration of cosmic ray muon radiography of reactor cores with nuclear emulsion based on an automated high-speed scanning technology, Proc. of the 26th Workshop on Radiation Detectors and Their Uses, 2012. ,
Surveillance: Radiographic imaging with cosmic-ray muons, Nature, vol.187, issue.6929, p.277, 2003. ,
DOI : 10.1016/0029-554X(81)90364-5
A scintillating fibres tracker detector for archaeological applications, Nuclear Instruments and Methods in Physics Research Section A: Accelerators, Spectrometers, Detectors and Associated Equipment, vol.572, issue.1, pp.262-265, 2007. ,
DOI : 10.1016/j.nima.2006.10.317
Imaging of underground cavities with cosmic-ray muons from observations at Mt. Echia (Naples), Scientific Reports, vol.7389, issue.Issue 6, p.1181, 2017. ,
DOI : 10.1016/S0168-9002(97)00048-X
Searching for cavities in the Teotihuacan Pyramid of the Sun using cosmic muons experiments and instrumentation, International Cosmic Ray Conference, vol.4, p.325, 2011. ,
Nuclear emulsion readout system HTS aiming at scanning an area of one thousand square meters. e-Print: arXiv, 1704, p.6814, 2017. ,
Development of an automated nuclear emulsion analyzing system, Radiation Measurements, vol.50, pp.237-240, 2013. ,
DOI : 10.1016/j.radmeas.2012.06.016
Comprehensive track reconstruction tool ``NETSCAN 2.0'' for the analysis of the OPERA Emulsion Cloud Chamber, Journal of Instrumentation, vol.7, issue.07, p.7001, 2012. ,
DOI : 10.1088/1748-0221/7/07/P07001
GEANT4?a simulation toolkit. Nuclear instruments and methods in physics research section A: Accelerators, Spectrometers, Detectors and Associated Equipment, pp.250-303, 2003. ,
URL : https://hal.archives-ouvertes.fr/in2p3-00020246
Latest Developments in Nuclear Emulsion Technology, Physics Procedia, vol.80, pp.19-24, 2015. ,
DOI : 10.1016/j.phpro.2015.11.082
URL : https://doi.org/10.1016/j.phpro.2015.11.082
Long Term Property of Nuclear Emulsion, Program and Proceedings of The 1st International Conference on Advanced Imaging (ICAI2015), pp.668-671, 2015. ,
The Fully Automated Emulsion Analysis System. Nuclear Instruments and Methods in Physics Research Section B: Beam Interactions with, Materials and Atoms, vol.51, pp.466-472, 1990. ,
DOI : 10.1016/0168-583x(90)90569-g
Development of a new automatic nuclear emulsion scanning system, S-UTS, with continuous 3D tomographic image read-out, Journal of Instrumentation, vol.5, issue.04, p.4011, 2010. ,
DOI : 10.1088/1748-0221/5/04/P04011
Rapporteur paper on muons and neutrinos, 13th International cosmic ray conference, 1973. ,
La chambre de Cheops: analyse architecturale (Fayard, 2004. ,
A simple parameterization of the cosmic-ray muon momentum spectra at the surface as a function of zenith angle. arXiv preprint, p.604145, 2006. ,
Cosmic-ray muon spectrum up to 1 TeV at 75?? zenith angle, Physical Review D, vol.15, issue.5, p.1368, 1979. ,
DOI : 10.1103/PhysRevD.15.820
MICROMEGAS: a high-granularity position-sensitive gaseous detector for high particle-flux environments, Nuclear Instruments and Methods in Physics Research Section A: Accelerators, Spectrometers, Detectors and Associated Equipment, vol.376, issue.1, pp.29-35, 1996. ,
DOI : 10.1016/0168-9002(96)00175-1
Micromegas in a bulk. Nuclear Instruments and Methods in Physics Research Section A: Accelerators, Spectrometers , Detectors and Associated Equipment, pp.405-408, 2006. ,
DOI : 10.1016/j.nima.2005.12.222
A spark-resistant bulk-micromegas chamber for high-rate applications. Nuclear Instruments and Methods in Physics Research Section A: Accelerators, Spectrometers, Detectors and Associated Equipment, pp.110-118, 2011. ,
DOI : 10.1016/j.nima.2011.03.025
URL : http://arxiv.org/pdf/1011.5370
Genetic multiplexing and first results with a 50x50cm 2 Micromegas. Nuclear Instruments and Methods in Physics Research Section A: Accelerators, Spectrometers , Detectors and Associated Equipment 729, pp.888-894, 2013. ,
DOI : 10.1016/j.nima.2013.08.071
A Micromegas-based telescope for muon tomography: The WatTo experiment. Nuclear Instruments and Methods in Physics Research Section A: Accelerators, Spectrometers, Detectors and Associated Equipment, pp.223-228, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01467614
Dream: a 64-channel Front-end Chip with Analogue Trigger Latency Buffer for the Micromégas Tracker of the CLAS12 Experiment, Proc. of TWEPP conference, 2014. ,
ROOT ??? An object oriented data analysis framework, Nuclear Instruments and Methods in Physics Research Section A: Accelerators, Spectrometers, Detectors and Associated Equipment, vol.389, issue.1-2, pp.81-86, 1997. ,
Photogrammetry: geometry from images and laser scans, 2007. ,
DOI : 10.1515/9783110892871
