Performance of Balanced Fairness in Resource Pools: A Recursive Approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Proceedings of the ACM on Measurement and Analysis of Computing Systems Année : 2017
Understanding the performance of a pool of servers is crucial for proper dimensioning. One of the main challenges is to take into account the complex interactions between servers that are pooled to process jobs. In particular, a job can generally not be processed by any server of the cluster due to various constraints like data locality. In this paper, we represent these constraints by some assignment graph between jobs and servers. We present a recursive approach to computing performance metrics like mean response times when the server capacities are shared according to balanced fairness. While the computational cost of these formulas can be exponential in the number of servers in the worst case, we illustrate their practical interest by introducing broad classes of pool structures that can be exactly analyzed in polynomial time. This extends considerably the class of models for which explicit performance metrics are accessible.
paper.pdf (363.41 Ko) Télécharger le fichier
hal-01630420 , version 1 (07-11-2017)
hal-01630420 , version 2 (18-12-2017)
hal-01630420 , version 3 (30-09-2019)
Thomas Bonald, Céline Comte, Fabien Mathieu. Performance of Balanced Fairness in Resource Pools: A Recursive Approach. Proceedings of the ACM on Measurement and Analysis of Computing Systems , 2017, 1 (2), pp.1-25. ⟨10.1145/3154500⟩. ⟨hal-01630420v3⟩
699 Consultations
313 Téléchargements
