Journal articles
Using Centroidal Voronoi Tessellations to Scale Up the Multi-dimensional Archive of Phenotypic Elites Algorithm
Vassilis Vassiliades 1 Konstantinos Chatzilygeroudis 1 Jean-Baptiste Mouret 1
1 LARSEN - Lifelong Autonomy and interaction skills for Robots in a Sensing ENvironment
Inria Nancy - Grand Est, LORIA - AIS - Department of Complex Systems, Artificial Intelligence & Robotics
Abstract : The recently introduced Multi-dimensional Archive of Phenotypic Elites (MAP-Elites) is an evolutionary algorithm capable of producing a large archive of diverse, high-performing solutions in a single run. It works by discretizing a continuous feature space into unique regions according to the desired discretization per dimension. While simple, this algorithm has a main drawback: it cannot scale to high-dimensional feature spaces since the number of regions increase exponentially with the number of dimensions. In this paper, we address this limitation by introducing a simple extension of MAP-Elites that has a constant, pre-defined number of regions irrespective of the dimensionality of the feature space. Our main insight is that methods from computational geometry could partition a high-dimensional space into well-spread geometric regions. In particular, our algorithm uses a centroidal Voronoi tessellation (CVT) to divide the feature space into a desired number of regions; it then places every generated individual in its closest region, replacing a less fit one if the region is already occupied. We demonstrate the effectiveness of the new " CVT-MAP-Elites " algorithm in high-dimensional feature spaces through comparisons against MAP-Elites in maze navigation and hexapod locomotion tasks.
Complete list of metadata
Cited literature [42 references]  Display  Hide  Download
https://hal.inria.fr/hal-01630627
Contributor : Jean-Baptiste Mouret Connect in order to contact the contributor
Submitted on : Tuesday, November 7, 2017 - 8:13:52 PM
Last modification on : Friday, July 8, 2022 - 10:10:32 AM
Long-term archiving on: : Thursday, February 8, 2018 - 3:03:57 PM
File
ieee_tec_voronoi_map_elites.pd...
Identifiers
Collections
Citation
Vassilis Vassiliades, Konstantinos Chatzilygeroudis, Jean-Baptiste Mouret. Using Centroidal Voronoi Tessellations to Scale Up the Multi-dimensional Archive of Phenotypic Elites Algorithm. IEEE Transactions on Evolutionary Computation, Institute of Electrical and Electronics Engineers, 2017, pp.9. ⟨10.1109/TEVC.2017.2735550⟩. ⟨hal-01630627⟩
Share
Metrics
Record views
145
Files downloads
216
