Journal articles
Asynchronous synthesis techniques for coordinating autonomic managers in the cloud
Rim Abid 1 Gwen Salaün 1 Noël de Palma 2
1 CONVECS - Construction of verified concurrent systems
Inria Grenoble - Rhône-Alpes, LIG - Laboratoire d'Informatique de Grenoble
2 ERODS - Efficient and Robust Distributed Systems
Abstract : Cloud computing allows the delivery of on-demand computing resources over the internet on a pay-for-use basis. From a technical point of view, cloud applications usually consist of several software components deployed on remote virtual machines. Managing such applications is a challenging problem because manual administration is no longer realistic for these complex distributed systems. Thus, autonomic computing is a promising solution for monitoring and updating these applications automatically. This is achieved through the automation of administration functions and the use of control loops called autonomic managers. An autonomic manager observes the environment , detects changes, and reconfigures dynamically the application. Multiple autonomic managers can be deployed in the same system and must make consistent decisions. Using them without coordination may lead to inconsistencies and error-prone situations. In this article, we first present a simple language for expressing coordination constraints given a set of auto-nomic managers. Second, given a coordination expression written with that language, we propose new synthesis techniques for automatically generating an asynchronous controller. These synthesis techniques work in two steps by successively generating a model of the controller and a Java object corresponding to this model. This Java code is finally used for deploying the generated controller. As far as evaluation is concerned, we validated our approach by using it for coordinating real-world cloud applications.
Complete list of metadata
Cited literature [26 references]  Display  Hide  Download
https://hal.inria.fr/hal-01630717
Contributor : Radu Mateescu Connect in order to contact the contributor
Submitted on : Wednesday, November 8, 2017 - 9:14:49 AM
Last modification on : Thursday, October 21, 2021 - 3:52:38 AM
Long-term archiving on: : Friday, February 9, 2018 - 12:50:19 PM
File
main_SCP_FACS.pdf
Identifiers
Citation
Rim Abid, Gwen Salaün, Noël de Palma. Asynchronous synthesis techniques for coordinating autonomic managers in the cloud. Science of Computer Programming, Elsevier, 2017, 146, pp.87 - 103. ⟨10.1016/j.scico.2017.05.005⟩. ⟨hal-01630717⟩
Share
Metrics
Record views
437
Files downloads
519
