On solving contact problems with Coulomb friction: formulations and numerical comparisons
Sur la résolution du problème de frottement tridimensionnel : Formulations et comparaisons des méthodes numériques
In this report, we review several formulations of the discrete frictional contact problem
that arises in space and time discretized mechanical systems with unilateral contact and
three-dimensional Coulomb’s friction. Most of these formulations are well–known concepts in the
optimization community, or more generally, in the mathematical programming community. To
cite a few, the discrete frictional contact problem can be formulated as variational inequalities,
generalized or semi–smooth equations, second–order cone complementarity problems, or as optimization
problems such as quadratic programming problems over second-order cones. Thanks to
these multiple formulations, various numerical methods emerge naturally for solving the problem.
We review the main numerical techniques that are well-known in the literature and we also propose
new applications of methods such as the fixed point and extra-gradient methods with self-adaptive
step rules for variational inequalities or the proximal point algorithm for generalized equations.
All these numerical techniques are compared over a large set of test examples using performance
profiles. One of the main conclusion is that there is no universal solver. Nevertheless, we are able
to give some hints to choose a solver with respect to the main characteristics of the set of tests
Dans ce rapport, plusieurs formulations du problème discret de contact frottant qui apparaît
dans les systèmes mécaniques avec du contact unilatéral et du frottement de Coulomb, sont présentées.
La plupart de ces formulations sont des objets bien connus dans la communauté de l’optimisation, et
plus généralement, de la programmation mathématique. Pour en citer quelques uns, le problème de
contact frottant peut être formulé comme une inégalité variationnelle, comme une équation non-régulière
ou semi–lisse, comme un problème de complémentarité sur des cônes, ou encore comme des problèmes
d’optimisation par exemple des problèmes quadratiques sur des cônes du second ordre. Grâce à ces
multiples formulations, de nombreuses méthodes numériques de résolutions émergent naturellement. On
détaille dans ce rapport les principales techniques numériques bien connues dans la littérature et nous
proposons aussi des nouvelles méthodes comme les méthodes de point fixe et d’extra-gradient pour les
inégalités variationnelles avec une règle d’adaptation automatique du pas, ainsi que l’application de
l’algorithme du point optimal pour les équations généralisées. Toutes ces techniques sont comparées sur
un grand ensemble de problème–tests en utilisant des profils de performance. Une des conclusions est qu’il
n’existe pas de méthode universelle. Néanmoins, on peut donner des conseils pour choisir une méthode
particulière la mieux adaptée aux caractéristiques d’un problème donné.
Domains
Mathematics [math] Numerical Analysis [math.NA] Engineering Sciences [physics] Mechanics [physics.med-ph] Materials and structures in mechanics [physics.class-ph] Engineering Sciences [physics] Mechanics [physics.med-ph] Structural mechanics [physics.class-ph] Computer Science [cs] Graphics [cs.GR]
