Learning the parts of objects with nonnegative matrix factorization, Nature, vol.401, pp.788-791, 1999. ,
Monaural Sound Source Separation by Nonnegative Matrix Factorization With Temporal Continuity and Sparseness Criteria, IEEE Transactions on Audio, Speech and Language Processing, vol.15, issue.3, pp.1066-1074, 2007. ,
DOI : 10.1109/TASL.2006.885253
Single-channel speech separation using sparse non-negative matrix factorization, Spoken Language Proceesing, ISCA International Conference on (INTERSPEECH), 2006. ,
Text-informed audio source separation. example-based approach using non-negative matrix partial cofactorization, Journal of Signal Processing Systems, vol.79, issue.2, pp.117-131, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-00870066
Nonnegative Matrix Factorization with the Itakura-Saito Divergence: With Application to Music Analysis, Neural Computation, vol.14, issue.3, pp.793-830, 2009. ,
DOI : 10.1016/j.sigpro.2007.01.024
On-the-Fly Audio Source Separation???A Novel User-Friendly Framework, IEEE/ACM Transactions on Audio, Speech, and Language Processing, vol.25, issue.2, pp.261-272, 2017. ,
DOI : 10.1109/TASLP.2016.2632528
URL : https://hal.archives-ouvertes.fr/hal-01400990
Adaptive Harmonic Spectral Decomposition for Multiple Pitch Estimation, IEEE Transactions on Audio, Speech, and Language Processing, vol.18, issue.3, pp.528-537, 2010. ,
DOI : 10.1109/TASL.2009.2034186
URL : https://hal.archives-ouvertes.fr/inria-00544094
A General Flexible Framework for the Handling of Prior Information in Audio Source Separation, IEEE Transactions on Audio, Speech, and Language Processing, vol.20, issue.4, pp.1118-1133, 2012. ,
DOI : 10.1109/TASL.2011.2172425
URL : https://hal.archives-ouvertes.fr/inria-00536917
Supervised and Unsupervised Speech Enhancement Using Nonnegative Matrix Factorization, IEEE Transactions on Audio, Speech, and Language Processing, vol.21, issue.10, pp.2140-2151, 2013. ,
DOI : 10.1109/TASL.2013.2270369
URL : http://kth.diva-portal.org/smash/get/diva2:634165/FULLTEXT02
Non-negative tensor factorisation for sound source separation, IEE Irish Signals and Systems Conference 2005, 2005. ,
DOI : 10.1049/cp:20050279
Multichannel Nonnegative Matrix Factorization in Convolutive Mixtures for Audio Source Separation, IEEE Transactions on Audio, Speech, and Language Processing, vol.18, issue.3, pp.550-563, 2010. ,
DOI : 10.1109/TASL.2009.2031510
A Robust and Precise Method for Solving the Permutation Problem of Frequency-Domain Blind Source Separation, IEEE Transactions on Speech and Audio Processing, vol.12, issue.5, pp.530-538, 2004. ,
DOI : 10.1109/TSA.2004.832994
An EM algorithm for localizing multiple sound sources in reverberant environments, NIPS, 2006. ,
Multichannel nonnegative tensor factorization with structured constraints for user-guided audio source separation, 2011 IEEE International Conference on Acoustics, Speech and Signal Processing (ICASSP), pp.257-260, 2011. ,
DOI : 10.1109/ICASSP.2011.5946389
URL : https://hal.archives-ouvertes.fr/inria-00564851
Multichannel Extensions of Non-Negative Matrix Factorization With Complex-Valued Data, IEEE Transactions on Audio, Speech, and Language Processing, vol.21, issue.5, pp.971-982, 2013. ,
DOI : 10.1109/TASL.2013.2239990
Direction of Arrival Based Spatial Covariance Model for Blind Sound Source Separation, IEEE/ACM Transactions on Audio, Speech, and Language Processing, vol.22, issue.3, pp.727-739, 2014. ,
DOI : 10.1109/TASLP.2014.2303576
Under-Determined Reverberant Audio Source Separation Using a Full-Rank Spatial Covariance Model, IEEE Transactions on Audio, Speech, and Language Processing, vol.18, issue.7, pp.1830-1840, 2010. ,
DOI : 10.1109/TASL.2010.2050716
URL : https://hal.archives-ouvertes.fr/inria-00435807
Maximum likelihood approach for blind audio source separation using time-frequency Gaussian source models, IEEE Workshop on Applications of Signal Processing to Audio and Acoustics, 2005., pp.78-81, 2005. ,
DOI : 10.1109/ASPAA.2005.1540173
Underdetermined Instantaneous Audio Source Separation via Local Gaussian Modeling, International Conference on Independent Component Analysis and Signal Separation, pp.775-782, 2009. ,
DOI : 10.1109/TSP.2004.828896
URL : https://hal.archives-ouvertes.fr/hal-00482223
Statistical Model of Speech Signals Based on Composite Autoregressive System with Application to Blind Source Separation, International Conference on Latent Variable Analysis and Signal Separation, pp.245-253, 2010. ,
DOI : 10.1007/978-3-642-15995-4_31
A unified approach for underdetermined blind signal separation and source activity detection by multichannel factorial hidden markov models, INTERSPEECH, pp.850-854, 2014. ,
Parametric Coding of Stereo Audio, EURASIP Journal on Advances in Signal Processing, vol.2005, issue.9, pp.1305-1322, 2005. ,
DOI : 10.1155/ASP.2005.1305
URL : https://doi.org/10.1155/asp.2005.1305
Model-Based Expectation-Maximization Source Separation and Localization, IEEE Transactions on Audio, Speech, and Language Processing, vol.18, issue.2, pp.382-394, 2010. ,
DOI : 10.1109/TASL.2009.2029711
URL : http://www.ee.columbia.edu/%7Eronw/pubs/taslp09-messl.pdf
Underdetermined Source Separation with Structured Source Priors, International Conference on Independent Component Analysis and Signal Separation, pp.327-334, 2004. ,
DOI : 10.1007/978-3-540-30110-3_42
URL : https://hal.archives-ouvertes.fr/inria-00544694
Musical source separation using time-frequency source priors, IEEE Transactions on Audio, Speech and Language Processing, vol.14, issue.1, pp.91-98, 2006. ,
DOI : 10.1109/TSA.2005.860342
URL : https://hal.archives-ouvertes.fr/inria-00544269
Nonnegative matrix factorization and spatial covariance model for under-determined reverberant audio source separation, 10th International Conference on Information Science, Signal Processing and their Applications (ISSPA 2010), pp.1-4, 2010. ,
DOI : 10.1109/ISSPA.2010.5605570
URL : https://hal.archives-ouvertes.fr/inria-00541436
Analysis of polyphonic audio using sourcefilter model and non-negative matrix factorization, Advances in models for acoustic processing, neural information processing systems workshop. Citeseer, 2006. ,
Multi-Channel Audio Source Separation Using Multiple Deformed References, IEEE/ACM Transactions on Audio, Speech, and Language Processing, vol.23, issue.11, pp.1775-1787, 2015. ,
DOI : 10.1109/TASLP.2015.2450494
Automatic Relevance Determination in Nonnegative Matrix Factorization with the /spl beta/-Divergence, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.35, issue.7, pp.1592-1605, 2013. ,
DOI : 10.1109/TPAMI.2012.240
Parafac. tutorial and applications Chemometrics and intelligent laboratory systems, pp.149-171, 1997. ,
Convolutive blind separation of non-stationary sources, IEEE transactions on Speech and Audio Processing, pp.320-327, 2000. ,
DOI : 10.1109/89.841214
A Consolidated Perspective on Multimicrophone Speech Enhancement and Source Separation, IEEE/ACM Transactions on Audio, Speech, and Language Processing, vol.25, issue.4, pp.692-730, 2017. ,
DOI : 10.1109/TASLP.2016.2647702
URL : https://hal.archives-ouvertes.fr/hal-01414179
Spatial location priors for Gaussian model based reverberant audio source separation, EURASIP Journal on Advances in Signal Processing, vol.92, issue.4, p.149, 2013. ,
DOI : 10.1007/978-3-642-15995-4_8
URL : https://hal.archives-ouvertes.fr/hal-00727781
Multichannel High-Resolution NMF for Modeling Convolutive Mixtures of Non-Stationary Signals in the Time-Frequency Domain, IEEE/ACM Transactions on Audio, Speech, and Language Processing, vol.22, issue.11, pp.1670-1680, 2014. ,
DOI : 10.1109/TASLP.2014.2341920
An inverse-gamma source variance prior with factorized parameterization for audio source separation, 2016 IEEE International Conference on Acoustics, Speech and Signal Processing (ICASSP), pp.136-140, 2016. ,
DOI : 10.1109/ICASSP.2016.7471652
URL : https://hal.archives-ouvertes.fr/hal-01253169
Multichannel harmonic and percussive component separation by joint modeling of spatial and spectral continuity, 2011 IEEE International Conference on Acoustics, Speech and Signal Processing (ICASSP), pp.205-208, 2011. ,
DOI : 10.1109/ICASSP.2011.5946376
URL : https://hal.archives-ouvertes.fr/inria-00557145
Underdetermined blind separation and tracking of moving sources based on DOA-HMM, Acoustics, Speech and Signal Processing (ICASSP), 2014 IEEE International Conference on, pp.3191-3195, 2014. ,
A Variational EM Algorithm for the Separation of Time-Varying Convolutive Audio Mixtures, IEEE/ACM Transactions on Audio, Speech, and Language Processing, vol.24, issue.8, pp.1408-1423, 2016. ,
DOI : 10.1109/TASLP.2016.2554286
URL : https://hal.archives-ouvertes.fr/hal-01301762
Online speech source separation based on maximum likelihood of local Gaussian modeling, 2011 IEEE International Conference on Acoustics, Speech and Signal Processing (ICASSP), pp.213-216, 2011. ,
DOI : 10.1109/ICASSP.2011.5946378
A General Framework for Online Audio Source Separation, International conference on Latent Variable Analysis and Signal Separation, pp.397-404, 2012. ,
DOI : 10.1007/978-3-662-04619-7
URL : https://hal.archives-ouvertes.fr/hal-00655398
Under-determined reverberant audio source separation using local observed covariance and auditorymotivated time-frequency representation, International Conference on Latent Variable Analysis and Signal Separation, pp.73-80, 2010. ,
DOI : 10.1007/978-3-642-15995-4_10
URL : https://hal.archives-ouvertes.fr/inria-00541868
Variational Bayesian Inference for Source Separation and Robust Feature Extraction, IEEE/ACM Transactions on Audio, Speech, and Language Processing, vol.24, issue.10, pp.1746-1758, 2016. ,
DOI : 10.1109/TASLP.2016.2583794
Maximum likelihood from incomplete data via the EM algorithm, Journal of the Royal Statistical Society: Series B (Statistical Methodology), vol.39, pp.1-38, 1977. ,
A fast EM algorithm for Gaussian model-based source separation, Signal Processing Conference (EUSIPCO), 2013 Proceedings of the 21st European, pp.1-5, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00840366
A Tutorial on MM Algorithms, The American Statistician, vol.58, issue.1, pp.30-37, 2004. ,
DOI : 10.1198/0003130042836
