Bottom-up automata on data trees and vertical XPath - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Logical Methods in Computer Science Année : 2017
A data tree is a finite tree whose every node carries a label from a finite alphabet and a datum from some infinite domain. We introduce a new model of automata over unranked data trees with a decidable emptiness problem. It is essentially a bottom-up alternating automaton with one register that can store one data value and can be used to perform equality tests with the data values occurring within the subtree of the current node. We show that it captures the expressive power of the vertical fragment of XPath —containing the child, descendant, parent and ancestor axes— obtaining thus a decision procedure for its satisfiability problem.
1710.08748.pdf (2.76 Mo) Télécharger le fichier
hal-01631219 , version 1 (20-02-2018)
Diego Figueira, Luc Segoufin. Bottom-up automata on data trees and vertical XPath. Logical Methods in Computer Science, 2017, 13 (4), ⟨10.23638/LMCS-13(4:5)2017⟩. ⟨hal-01631219⟩
223 Consultations
58 Téléchargements
