The challenge of mapping the human connectome based on diffusion tractography
(1)
(1)
(2)
(2)
(2)
(3)
(2)
(4)
(5)
(6)
(6)
(6)
(7)
(8)
(8)
(8)
(9)
(9)
(9)
(10)
(2)
(11)
(2)
(2)
(12)
(2)
(2)
(13)
(13)
(13)
(13)
(14)
(13)
(13)
(15)
(15, 16)
(15, 17)
(15)
(15)
(15)
(2)
(18)
(18)
(18)
(19)
(20)
(21)
(21)
(22)
(22)
(22)
(23)
(23)
(22)
(24)
(24)
(24)
(24)
(25)
(25)
(25)
(25)
(25)
(26)
(26)
(26)
(26)
(26)
(26)
(27)
(28)
(21, 29)
(30, 31)
(1)
(32)
(33)
(2)
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
Klaus H Maier-Hein
Connectez-vous pour contacter l'auteur
- Function : Correspondent author
- PersonId : 1022449
Samuel Deslauriers-Gauthier
- Function : Author
- PersonId : 750858
- IdHAL : samuel-deslauriers-gauthier
- ORCID : 0000-0003-2781-121X
Michael Paquette
- Function : Author
- PersonId : 768614
- ORCID : 0000-0002-8917-3391
Samuel St-Jean
- Function : Author
- PersonId : 768615
- ORCID : 0000-0002-8092-2974
Gabriel Girard
- Function : Author
- PersonId : 771524
- IdRef : 193861070
François Rheault
- Function : Author
- PersonId : 784575
- ORCID : 0000-0002-0097-8004
Martijn Froeling
- Function : Author
- PersonId : 784752
- ORCID : 0000-0003-3841-0497
Aldo Quattrone
- Function : Author
- PersonId : 899771
Oscar Esteban
- Function : Author
- PersonId : 771984
- ORCID : 0000-0001-8435-6191
Laurent Petit
- Function : Author
- PersonId : 174786
- IdHAL : laurent-petit
- ORCID : 0000-0003-2499-5367
- IdRef : 087584751
Emmanuel Caruyer
- Function : Author
- PersonId : 740306
- IdHAL : emmanuel-caruyer
- ORCID : 0000-0002-8547-7726
- IdRef : 237499789
Maxime Descoteaux
- PersonId : 841776
Tractography based on non-invasive diffusion imaging is central to the study of human brain connectivity. To date, the approach has not been systematically validated in ground truth studies. Based on a simulated human brain data set with ground truth tracts, we organized an open international tractography challenge, which resulted in 96 distinct submissions from 20 research groups. Here, we report the encouraging finding that most state-of-the-art algorithms produce tractograms containing 90% of the ground truth bundles (to at least some extent). However, the same tractograms contain many more invalid than valid bundles, and half of these invalid bundles occur systematically across research groups. Taken together, our results demonstrate and confirm fundamental ambiguities inherent in tract reconstruction based on orientation information alone, which need to be considered when interpreting tractography and connectivity results. Our approach provides a novel framework for estimating reliability of tractography and encourages innovation to address its current limitations.
