Blind Source Separation Using Mixtures of Alpha-Stable Distributions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2017
We propose a new blind source separation algorithm based on mixtures of alpha-stable distributions. Complex symmetric alpha-stable distributions have been recently showed to better model audio signals in the time-frequency domain than classical Gaussian distributions thanks to their larger dynamic range. However, inference of these models is notoriously hard to perform because their probability density functions do not have a closed-form expression in general. Here, we introduce a novel method for estimating mixture of alpha-stable distributions based on random moment matching. We apply this to the blind estimation of binary masks in individual frequency bands from multichannel convolutive audio mixes. We show that the proposed method yields better separation performance than Gaussian-based binary-masking methods.
alphabss.pdf (309.87 Ko) Télécharger le fichier
IEEEbib.bst (17.48 Ko) Télécharger le fichier
hal-01633215 , version 1 (11-11-2017)
hal-01633215 , version 2 (15-11-2017)
hal-01633215 , version 3 (09-02-2018)
Nicolas Keriven, Antoine Deleforge, Antoine Liutkus. Blind Source Separation Using Mixtures of Alpha-Stable Distributions. 2017. ⟨hal-01633215v2⟩
1168 Consultations
519 Téléchargements
