Stochastic computing, Proceedings of the April 18-20, 1967, spring joint computer conference on, AFIPS '67 (Spring), pp.149-156, 1967. ,
DOI : 10.1145/1465482.1465505
Survey of Stochastic Computing, ACM Transactions on Embedded Computing Systems, vol.12, issue.2s, p.92, 2013. ,
DOI : 10.1145/2465787.2465794
URL : http://web.eecs.umich.edu/~jhayes/Alaghi_Hayes_Survey_of_SC_Dec-11.pdf
An Architecture for Fault-Tolerant Computation with Stochastic Logic, IEEE Transactions on Computers, vol.60, issue.1, pp.93-105, 2011. ,
DOI : 10.1109/TC.2010.202
Computation on Stochastic Bit Streams Digital Image Processing Case Studies, IEEE Transactions on Very Large Scale Integration (VLSI) Systems, pp.449-462, 2014. ,
DOI : 10.1109/TVLSI.2013.2247429
Exploiting correlation in stochastic circuit design, 2013 IEEE 31st International Conference on Computer Design (ICCD), pp.39-46, 2013. ,
DOI : 10.1109/ICCD.2013.6657023
Analyzing and controlling accuracy in stochastic circuits, 2014 IEEE 32nd International Conference on Computer Design (ICCD), pp.367-373, 2014. ,
DOI : 10.1109/ICCD.2014.6974707
Effect of bit-level correlation in stochastic computing, 2015 IEEE International Conference on Digital Signal Processing (DSP), pp.463-467, 2015. ,
DOI : 10.1109/ICDSP.2015.7251915
Stochastic circuits for real-time image-processing applications, Proceedings of the 50th Annual Design Automation Conference on, DAC '13, 2013. ,
DOI : 10.1145/2463209.2488901
Design of Division Circuits for Stochastic Computing, 2016 IEEE Computer Society Annual Symposium on VLSI (ISVLSI), pp.116-121, 2016. ,
DOI : 10.1109/ISVLSI.2016.48
