Analysis of the Failure Tolerance of Linear Access Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Intelligent Transportation Systems Année : 2017
In this paper, we study the disconnection of a moving vehicle from a linear access network composed by cheap WiFi Access Points in the context of the telecommuting in massive transportation systems. In concrete, we analyze the probability for a user to experience a disconnection longer than a given time interval (t *) such that all ongoing communications between the vehicle and the infrastructure network are disrupted. We provide an approximation formula considering two scenarios (intercity bus and train). We then carry out a sensitivity analysis and supply a guide for operators when choosing the parameters of the networks. Last, we show that such systems are viable, as they attain a very low probability of long disconnections with a very low maintenance cost.
FINAL VERSION.pdf (587.5 Ko) Télécharger le fichier
hal-01633813 , version 1 (14-11-2017)
Frédéric Giroire, Juan-Carlos Maureira. Analysis of the Failure Tolerance of Linear Access Networks. IEEE Transactions on Intelligent Transportation Systems, 2017, pp.1 - 10. ⟨10.1109/TITS.2017.2718737⟩. ⟨hal-01633813⟩
175 Consultations
155 Téléchargements
