Journal articles
SMART 2013: Experimental and numerical assessment of the dynamic behavior by shaking table tests of an asymmetrical reinforced concrete structure subjected to high intensity ground motions
Abstract : As part of a large research program launched and funded by the French Atomic Energy and Sustainable Energies Commission (CEA) and Electricité De France (EDF), partially supported by the International Atomic Energy Agency (IAEA) and entitled ‘‘Seismic design and best-estimate Methods Assessment for Reinforced concrete buildings subjected to Torsion and nonlinear effect (SMART)”, a series of shaking table tests on a ¼-scale 3-story reinforced concrete model characterized by a strong asymmetry has been carried out in July 2013. The seismic loading was composed of three test sequences having different peak ground accelerations (PGA): the design level signal (PGA equal to 0.2 g), the Northridge main shock signal (PGA equal to 1.78 g) and a Northridge aftershock (PGA equal to 0.33 g). In this paper, the main experimental results, compared with outputs from a numerical study carried out by CEA, are presented and discussed. The following conclusions were reached for each seismic test sequence: (i) only small nonlinearities appeared and both displacement and acceleration-based quantities were properly estimated by the model; (ii) the specimen exhibited moderate nonlinearities in case of PGA higher than 4 or 5 times the design PGA; displacements were numerically underestimated whereas maximum acceleration-based quantities were captured rather well; (iii) the fact that no additional damage was monitored during this seismic sequence was pointed out only by the experimental measurements but also by the numerical outputs, leading to show that this aftershock signal did not induce any further damage. Given the aforementioned observations, it was possible to carry out a robustness analysis based upon two damage indicators: the eigenfrequency shift and the inter-story drift. Apart from the issues of the most meaningful robustness indicator and the choice of damage thresholds that came up, it is shown that the specimen can be qualified as being robust.
Document type :
Journal articles
Complete list of metadata
Cited literature [50 references]  Display  Hide  Download
https://hal.archives-ouvertes.fr/hal-01634196
Contributor : François VOLDOIRE Connect in order to contact the contributor
Submitted on : Monday, December 2, 2019 - 5:15:02 PM
Last modification on : Wednesday, May 11, 2022 - 10:44:35 AM
Long-term archiving on: : Tuesday, March 3, 2020 - 11:03:25 PM
File
richard2016.pdf
Identifiers
Citation
Benjamin Richard, Stefano Cherubini, François Voldoire, Pierre-Etienne Charbonnel, Thierry Chaudat, et al.. SMART 2013: Experimental and numerical assessment of the dynamic behavior by shaking table tests of an asymmetrical reinforced concrete structure subjected to high intensity ground motions. Engineering Structures, Elsevier, 2016, 109, pp.99-116. ⟨10.1016/j.engstruct.2015.11.029⟩. ⟨hal-01634196⟩
Share
Metrics
Record views
488
Files downloads
112
