Seismic analysis of RC shear wall, Proceedings fourteenth international conference on structural mechanics in reactor technology, 1997. ,
Report on seismic shear wall international standard problem organized by OECD/NEA/CSNI, Proceedings fourteenth international conference on structural mechanics in reactor technology, 1997. ,
Study on the dynamic inelastic behavior of seismic shear walls of the reactor building, Proceedings fourteenth international conference on structural mechanics in reactor technology, 1997. ,
Nonlinear analysis of RC shear wall shaking table test, Proceedings fourteenth international conference on structural mechanics in reactor technology, 1997. ,
Nonlinear analysis of reinforced concrete shear wall under earthquake loading, J Earthquake Eng, vol.4, issue.2, pp.183-213, 2000. ,
The CAMUS research programme, Proceedings of the 11th European conference on earthquake engineering, pp.4-8, 1998. ,
CAMUS experimental program. In -plane tests of 1/3rd scaled R/C bearing walls, Proceedings of the 11th European conference on earthquake engineering, pp.4-8, 1998. ,
Conclusions of an IAEA-JRC research project on the safety significance of near-field seismic motions, Nucl Eng Des, vol.241, issue.5, pp.1842-56, 2011. ,
Shake-table test of a full-scale 7-story building slice. Phase I: rectangular wall, J Struct Eng, vol.137, issue.6, pp.691-704, 2011. ,
Lessons learned from seismic analysis of a seven-story concrete test building, J Earthquake Eng, vol.14, issue.3, pp.448-69, 2010. ,
Simulation of the shaking table test of a seven-story shear wall building, Earthq Eng Struct Dynam, vol.38, issue.5, pp.587-607, 2009. ,
Numerical modelling of the seismic behaviour of a 7-story building: NEES benchmark, Mater Struct, vol.42, issue.10, pp.1433-1475, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-01007147
A blind prediction test of nonlinear analysis procedures for reinforced concrete shear walls, NZSEE Bullet, vol.40, issue.3, pp.142-59, 2007. ,
Experimental studies of reinforced concrete structures under multi-directional earthquakes and design implications, 2013. ,
project experimental tests of a reinforced concrete building subjected to torsion, Proceedings 20th international conference on structural mechanics in reactor technology, 2008. ,
shaking table tests on an asymmetrical reinforced concrete structure and seismic margins assessment, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-01634202
Damping identification in shaking table tests, Proceedings of the technical innovation in nuclear civil engineering international conference (TINCE 2013), 2013. ,
Development and application of a displacement-based design approach for moment-resisting frame structures, pp.217-245, 1997. ,
Modelling of reinforced concrete structural walls, Eng Struct, vol.21, pp.912-935, 1999. ,
Flexural modeling of reinforced concrete walls -model attributes, ACI Struct J, vol.101, issue.5, pp.688-98, 2004. ,
Nonlinear behavior of reinforced concrete shear walls using macroscopic and microscopic models, Eng Struct, vol.32, pp.2959-68, 2010. ,
Analytical model for predicting nonlinear reversed cyclic behaviour of reinforced concrete structural walls, Eng Struct, vol.29, pp.1263-76, 2007. ,
Flexure-shear fiber beam-column elements for modeling frame structures under seismic loading -state of the art, J Earthq Eng, vol.11, issue.S1, pp.46-88, 2007. ,
Simplified model for damage in squat RC shear walls, Eng Struct, vol.31, issue.10, pp.2215-2238, 2009. ,
Performance of reinforced concrete shear walls with steel reinforced concrete boundary columns, Eng Struct, vol.44, pp.186-209, 2012. ,
Performance limits for structural walls: an analytical perspective, Eng Struct, vol.43, pp.105-124, 2012. ,
Performance of fiber beam-column elements in the seismic analysis of a lightly reinforced shear wall, Eng Struct, vol.49, pp.345-59, 2013. ,
