Inelastic finite element analysis of reinforced concrete panels under in-plane loads, 1979. ,
Some aspects of shear wall design, Bull N Z Soc Earthq Eng, vol.5, issue.3, 1972. ,
Cyclic load tests on shear wall panels, Proceedings of the fifth world conference on earthquake engineering, pp.1116-1125, 1973. ,
Strength of low-rise structural walls, ACI Special Publication, vol.63, 1980. ,
Ductility in earthquake resisting squat shear walls, ACI J Proc, vol.79, issue.4, 1982. ,
Seismic behavior of squat reinforced concrete shear walls, Earthq Spectra, vol.18, issue.2, pp.287-308, 2002. ,
Experimental investigation of the strength, stiffness and ductility of RC structural walls, In: World conference on earthquake engineering, vol.6, pp.387-94, 1998. ,
Analysis and tests on small-scale shear walls. FY-82 final report (No. NUREG/CR-4274; LA-10443-MS), 1985. ,
Behaviour of squat walls subjected to load reversals, 1985. ,
Seismic category I structures program: final report, FY 1983-84 (No. NUREG/CR-4924; LA-11013-MS), 1987. ,
Behavior of reinforced concrete structural walls: strength, deformation characteristics, and failure mechanism, ACI Struct J, vol.87, issue.1, 1990. ,
Programme SAFE: Rapport du test T5, 1998. ,
Simulation of reinforced concrete short shear wall subjected to cyclic loading, Nucl Eng Des, vol.270, pp.344-50, 2014. ,
Shear strength of low-rise walls with boundary elements, ACI Special Publication, vol.53, 1977. ,
Static load cycle testing of a low-aspect-ratio six ,
, Nuclear Regulatory Commission, 1989.
Low-aspect-ratio four-inch wall, TRG-type structure, 1990. ,
Static load cycle testing of a very low-aspect-ratio six-inch wall TRG-type structure ,
, Nuclear Regulatory Commission, Div. of Engineering, 1990.
Static and simulated seismic testing of the TRG-7 through-16 shear wall structures (No. NUREG/CR-5660 ,
, Los Alamos National Lab, 1991.
Relationship between force and displacement in RC structures for nuclear reactors ,
, , 1986.
Experimental study on dynamic properties of reinforced concrete shear walls, Proceedings of the 5th world conference on earthquake engineering, 1973. ,
Experimental study on the hysteretic behavior of reinforced concrete shear walls under the loading of different moment-toshear ratios, Trans Jpn Concr Inst, vol.6, pp.274-83, 1984. ,
Reinforced concrete shear wall assemblies, Trans Am Soc Civil Eng, vol.126, issue.2, pp.114-159, 1961. ,
Aseismic characteristics of RC box and cylinder walls, Proceedings of the sixth world conference on earthquake engineering, pp.3144-3153, 1976. ,
The response of shear walls subjected to dynamic loads ,
, Massachusetts Institute of Technology, 1957.
Model analysis of the response of shear walls to dynamic loads ,
Seismic fragility of reinforced concrete structures and components for application to nuclear facilities. Division of Engineering Technology, Office of Nuclear Regulatory Research, US Nuclear Regulatory Commission, 1985. ,
Test program on U-shaped walls leading to model validation and implication to design, Proceedings of the 12th European conference on earthquake engineering, 2002. ,
Shaking table test of Rc box-type shear wall in multi-axes loading, 13th world conference on earthquake engineering, 2004. ,
The physical basis of dimensional analysis. Cambridge (MA): Department of Mechanical Engineering, MIT, 2001. ,
Seismic testing of structures. Earthquake engineering-invited papers: proceedings of the eleventh European conference, vol.2, p.53, 1998. ,
Proposition de modification de la règle fondamentale de sûreté 1.2. c relative à la détermination des mouvements sismiques à prendre en compte pour la sûreté des tranches nucléaires comportant un réacteur à eau sous pression, applicable à l'ensemble des installations nucléaires de base, 1998. ,
Prise en compte du risque sismique à la conception des ouvrages de génie civil d'installations nucléaire de base à l'exception des stockages à long terme des déchets radioactifs. Guide de l'Autorité de Sureté Nucléaire, 2006. ,
Generation and characterization of synthetic signals: preliminary observations and developments. DEN technical report, SEMT/EMSI/RT/98-022/A, 1998. ,
, test report. DEN technical report, 2008.
, Metallic materials -tensile testing -Part, vol.1, pp.6892-6893, 2010.
European Macroseismic scale EMS-98, vol.15, 1998. ,
, Modal testing: theory and practice, vol.79, 1984.
Modal analysis theory and testing, 2006. ,
Applied frequency-domain system identification in the field of experimental and operational modal analysis. VUB, Brussel: Praca doktorska, 2004. ,
New results on the identification of normal modes from experimental complex modes, Mech Syst Signal Process, vol.11, issue.2, pp.229-272, 1997. ,
SMART 2008: overview, synthesis and lessons learnt from the International Benchmark, 2015. ,
Experimental modal analyses of the SMART 2008 RC specimen before and after being subjected to seismic loadings. EDF technical report. H-T61-2009-00261-FR, 2009. ,
Simulation of the shaking table test of a seven-story shear wall building, Earthq Eng Struct Dynam, vol.38, issue.5, pp.587-607, 2009. ,
Generation of seismic floor response spectra for equipment design, Structural design of nuclear plant facilities, pp.29-71, 1973. ,
Floor response spectra for bare and infilled reinforced concrete frames, J Earthq Eng, vol.18, issue.7, pp.1060-82, 2014. ,
Prestandard and commentary for the seismic rehabilitation of buildings, FEMA-356, Federal Emergency Management Agency, 2000. ,
On drift limits associated with different damage levels, International workshop on performance-based seismic design, vol.28, 2004. ,
, Eurocode 8 -design of structures for earthquake resistance -Part 1: General rules, seismic actions and rules for buildings, European Standard NF EN, issue.1, 1998.
, Seismic evaluation of existing nuclear power plants, safety reports series, 2003.
Conclusions of an IAEA-JRC research project on the safety significance of near-field seismic motions, Nucl Eng Des, vol.241, issue.5, pp.1842-56, 2011. ,
