Un modèle de matériau microfissuré pour les roches et les bétons, J. Méca. Théo. Appl, vol.5, pp.471-513, 1986. ,
On the failure analysis of bondlines: Stress or energy based fracture criteria?, Engineering Fracture Mechanics, vol.126, pp.108-125, 2014. ,
DOI : 10.1016/j.engfracmech.2014.04.024
Influence of strain rate on the seismic response of RC structures, Engineering Structures, vol.35, pp.29-36, 2012. ,
DOI : 10.1016/j.engstruct.2011.10.025
An explicit formulation for an efficient triangular plate-bending element, International Journal for Numerical Methods in Engineering, vol.6, issue.7, pp.1077-1089, 1982. ,
DOI : 10.1002/nme.1620180711
Crack band theory for fracture of concrete, Mater. Struct, vol.16, issue.93, pp.155-177, 1983. ,
Modélisation du comportement cyclique alterné du béton armé. Application à divers essais statiques de poteaux, 1997. ,
Thin elastic and periodic plates, Mathematical Methods in the Applied Sciences, vol.2, issue.18, pp.159-191, 1984. ,
DOI : 10.1007/BFb0091528
Bulletin d'information No. 195?196: Comité Euro- International du Béton, 1990. ,
Damage Mechanics, Comprehensive Structural Integrity, pp.213-284, 2003. ,
DOI : 10.1016/B0-08-043749-4/02085-1
A justification of a nonlinear model in plate theory, Computer Methods in Applied Mechanics and Engineering, vol.17, issue.18, pp.17-18, 1979. ,
DOI : 10.1016/0045-7825(79)90089-6
Homogenised constitutive model coupling damage and debonding for reinforced concrete structures under cyclic solicitations, International Journal of Solids and Structures, vol.50, issue.24, pp.3861-3874, 2013. ,
DOI : 10.1016/j.ijsolstr.2013.07.021
URL : https://hal.archives-ouvertes.fr/hal-01654802
Homogénéisation de structures minces en béton armé. RAIRO-Modélisation mathématique et analyse numérique, pp.1-47, 1986. ,
DOI : 10.1051/m2an/1986200100471
URL : http://www.esaim-m2an.org/10.1051/m2an/1986200100471/pdf
Coupled damage and plasticity models derived from energy and dissipation potentials, International Journal of Solids and Structures, vol.44, issue.7-8, pp.2487-2508, 2007. ,
DOI : 10.1016/j.ijsolstr.2006.07.019
URL : https://doi.org/10.1016/j.ijsolstr.2006.07.019
Local Bond Stress-Slip Relationships of Deformed Bars Under Generalized Excitations: Experimental Results and Analytical Model, Earthquake Engineering Research Center, 1983. ,
Ecrouissages-Schémas thermomécaniques et a variables internes: méthode de définition utilisant le concept d'hystérésis pure, Arch. Mech, vol.40, pp.5-6, 1988. ,
A composite plasticity model for concrete, International Journal of Solids and Structures, vol.33, issue.5, pp.707-730, 1996. ,
DOI : 10.1016/0020-7683(95)00060-N
Importance of the bond???slip mechanism in the numerical simulation of the cyclic response of RC elements with plain reinforcing bars, Engineering Structures, vol.56, pp.396-406, 2013. ,
DOI : 10.1016/j.engstruct.2013.05.013
Multiscale FE2 elastoviscoplastic analysis of composite structures, Computational Materials Science, vol.16, issue.1-4, pp.344-354, 1999. ,
DOI : 10.1016/S0927-0256(99)00077-4
Sur les matériaux standards généralisés, J. de Mécanique, vol.14, pp.39-63, 1975. ,
On Constitutive Macro-Variables for Heterogeneous Solids at Finite Strain, Proc. R. Soc. London Ser. A 326, pp.131-147, 1972. ,
DOI : 10.1098/rspa.1972.0001
Homogenized global nonlinear constitutive model for RC panels under cyclic loadings, 11th World Congress on Computational Mechanics (WCCM XI), 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01071399
Time of the rupture process under creep conditions, IVZ Akad. Nauk, S.S.R Otd. Tech. Nauk, vol.8, pp.26-31, 1958. ,
An elasto-plastic damage model for reinforced concrete with minimum number of material parameters, Computers & Structures, vol.82, issue.15-16, pp.1201-1215, 2004. ,
DOI : 10.1016/j.compstruc.2004.03.002
Contact density model for stress transfer across cracks in concrete, J. Faculty Eng. Univ. Tokyo, vol.40, pp.9-52, 1989. ,
Tension Chord Model for Structural Concrete, Structural Engineering International, vol.8, issue.4, pp.287-298, 1998. ,
DOI : 10.2749/101686698780488875
Numerical modelling of the cyclic behaviour of RC elements built with plain reinforcing bars, Engineering Structures, vol.33, issue.2, pp.273-286, 2011. ,
DOI : 10.1016/j.engstruct.2010.11.005
Homogénéisation de matériaux élastoplastiques avec cavités (Doctoral dissertation), 1984. ,
Modeling the bond-slip behaviour of confined large-diameter reinforcing bars, III ECCOMAS Thematic Conference on Computational Methods in Structural Dynamics and Earthquake Engineering, 2011. ,
Elastoplastic-damage modelling including the gradient of damage: formulation and computational aspects, International Journal of Solids and Structures, vol.38, issue.30-31, pp.5421-5451, 2001. ,
DOI : 10.1016/S0020-7683(00)00358-9
On the elastic plastic initial-boundary value problem and its numerical integration, Int. J. Numer. Methods Eng, vol.11, pp.817-832, 1977. ,
URL : https://hal.archives-ouvertes.fr/hal-00105639
Une analyse microm??canique 3-D de l'endommagement par m??sofissuration, Comptes Rendus de l'Acad??mie des Sciences - Series IIB - Mechanics, vol.329, issue.4, pp.271-276, 2001. ,
DOI : 10.1016/S1620-7742(01)01340-X
Extended cracked membrane model for the analysis of RC panels, Engineering Structures, vol.32, issue.8, pp.1964-1975, 2010. ,
DOI : 10.1016/j.engstruct.2010.02.030
Continuum damage mechanics based model for quasi brittle materials subjected to cyclic loadings: Formulation, numerical implementation and applications, Engineering Fracture Mechanics, vol.98, pp.383-406, 2013. ,
DOI : 10.1016/j.engfracmech.2012.11.013
Non-homogeneous Media and Vibration Theory, Lecture Notes in Physics, vol.127, 1980. ,
Homogenization Technique for Composite Media, 1987. ,
DOI : 10.1007/3-540-17616-0
A coupled elastoplastic damage model for semi-brittle materials and extension to unsaturated conditions, Mechanics of Materials, vol.38, issue.3, pp.218-232, 2006. ,
DOI : 10.1016/j.mechmat.2005.07.002
URL : https://hal.archives-ouvertes.fr/hal-00021987
Consistent tangent operators for rate-independent elastoplasticity, Computer Methods in Applied Mechanics and Engineering, vol.48, issue.1, pp.101-118, 1985. ,
DOI : 10.1016/0045-7825(85)90070-2
Thermodynamical Description of Running Discontinuities: Application to Friction and Wear, Entropy, vol.52, issue.12, pp.1418-1439, 2010. ,
DOI : 10.1016/j.triboint.2008.06.007
Introduction, Homogenization Techniques for Composite Media, pp.193-278, 1987. ,
DOI : 10.1007/3-540-17616-0_15
URL : https://hal.archives-ouvertes.fr/hal-00404025
Overall potentials and extremal surfaces of power law or ideally plastic composites, Journal of the Mechanics and Physics of Solids, vol.41, issue.6, pp.981-1002, 1993. ,
DOI : 10.1016/0022-5096(93)90051-G
Homogénéisation des structures hétérogènes. ISSN 1161-0611. Collection de notes internes de la Direction des Etudes et Recherches, 1993. ,
Numerically explicit potentials for the homogenization of nonlinear elastic heterogeneous materials, Computer Methods in Applied Mechanics and Engineering, vol.198, issue.33-36, pp.2723-2737, 2009. ,
DOI : 10.1016/j.cma.2009.03.017
URL : https://hal.archives-ouvertes.fr/hal-00692234
