Anisotropic model of damage for geomaterials and concrete, International Journal for Numerical and Analytical Methods in Geomechanics, vol.26, issue.9, pp.969-979, 2011. ,
DOI : 10.1016/j.ijfatigue.2004.02.006
A finite element model for the study of creep and shrinkage effects in composite beams with deformable shear connections, Costruzioni Metalliche, vol.4, pp.213-228, 1993. ,
Un modèle de matériau microfissuré pour les roches et les bétons, J. Méca. Théo. Appl, vol.5, pp.471-513, 1986. ,
Application of some anisotropic damage model to the prediction of the failure of some complex industrial concrete structure, International Journal of Solids and Structures, vol.44, issue.18-19, pp.5848-5874, 2007. ,
DOI : 10.1016/j.ijsolstr.2007.02.001
URL : https://hal.archives-ouvertes.fr/hal-00169822
Seismic damage in reinforced concrete frames, J. Struct. Div, vol.107, issue.9, pp.1713-1729, 1981. ,
Pseudo-dynamic tests on low-rise shear walls and simplified model based on the structural frequency drift, Engineering Structures, vol.33, issue.3, pp.796-812, 2010. ,
DOI : 10.1016/j.engstruct.2010.12.003
A simple shear wall model taking into account stiffness degradation, Engineering Structures, vol.25, issue.1, pp.1-9, 2003. ,
DOI : 10.1016/S0141-0296(02)00084-6
Thin elastic and periodic plates, Mathematical Methods in the Applied Sciences, vol.2, issue.18, pp.159-191, 1984. ,
DOI : 10.1007/BFb0091528
2D models of plate-like 3D elastic bodies In: Asymptotic Theories for Plates and Shells, Pitman Res. Notes in Math. S. Longman Sc. & Tech, vol.319, pp.28-34, 1995. ,
Hysteretic Behavior of RC Beams, Journal of Structural Engineering, vol.110, issue.9, pp.2073-2084, 1984. ,
DOI : 10.1061/(ASCE)0733-9445(1984)110:9(2073)
Damage Mechanics, Comprehensive Structural Integrity, pp.213-284, 2003. ,
DOI : 10.1016/B0-08-043749-4/02085-1
Thermodynamics with internal variables, J. Chem. Phys, vol.48, issue.2, pp.597-613, 1967. ,
DOI : 10.1063/1.1711937
URL : http://repository.cmu.edu/cgi/viewcontent.cgi?article=1082&context=math
A continuum model for plastic-brittle behaviour of rock and concrete, International Journal of Engineering Science, vol.17, issue.2, pp.121-137, 1979. ,
DOI : 10.1016/0020-7225(79)90058-2
Seismic Design, Assessment and Retrofitting of Concrete Buildings, 2009. ,
DOI : 10.1007/978-1-4020-9842-0
Measuring the stiffness of concrete shear walls during dynamic tests, Experimental Mechanics, vol.109, issue.5, pp.179-183, 1992. ,
DOI : 10.1007/BF02324730
Constitutive Model for Reinforced Concrete, Journal of Engineering Mechanics, vol.121, issue.5, pp.587-595, 1995. ,
DOI : 10.1061/(ASCE)0733-9399(1995)121:5(587)
URL : https://repository.tudelft.nl/islandora/object/uuid%3A1524fa58-c77c-4f9c-8a78-c4ac66b519fa/datastream/OBJ/download
Coupled damage and plasticity modelling in transient dynamic analysis of concrete, International Journal for Numerical and Analytical Methods in Geomechanics, vol.37, issue.1, pp.1-24, 2002. ,
DOI : 10.1016/0029-5493(76)90015-7
URL : https://hal.archives-ouvertes.fr/hal-00994422
Mécanique des Milieux Continus, 1973. ,
The Method of Virtual Power in Continuum Mechanics. Part 2: Microstructure, SIAM Journal on Applied Mathematics, vol.25, issue.3, pp.556-575, 1973. ,
DOI : 10.1137/0125053
Continuum Thermodynamics, Journal of Applied Mechanics, vol.50, issue.4b, pp.1010-1021, 1983. ,
DOI : 10.1115/1.3167184
URL : https://hal.archives-ouvertes.fr/hal-00105630
Cracks formed in concrete around deformed tension bars, J. ACI, vol.68, issue.4, pp.224-251, 1971. ,
A fibre Timoshenko beam element in Castem2000, Special publication Nr. I.94.31, Joint Research Center, 1994. ,
Sur les matériaux standards généralisés, J. de Mécanique, vol.14, pp.39-63, 1975. ,
On Constitutive Macro-Variables for Heterogeneous Solids at Finite Strain, Proc. R. Soc. London, pp.131-147, 1972. ,
DOI : 10.1098/rspa.1972.0001
Fracture Mechanics of Bond in Reinforced Concrete, Journal of Structural Engineering, vol.110, issue.4, pp.871-890, 1984. ,
DOI : 10.1061/(ASCE)0733-9445(1984)110:4(871)
A feasibility study of detecting reinforcing-bar debonding by acoustic-emission technique, Experimental Mechanics, vol.68, issue.4, pp.301-308, 1980. ,
DOI : 10.1007/BF02328623
Global Constitutive Model for Reinforced Concrete Plates, Journal of Engineering Mechanics, vol.133, issue.3, pp.257-266, 2007. ,
DOI : 10.1061/(ASCE)0733-9399(2007)133:3(257)
URL : https://hal.archives-ouvertes.fr/hal-00086333
The equivalent reinforced concrete model for simulating the behavior of walls under dynamic shear loading, Engineering Fracture Mechanics, vol.70, issue.7-8, pp.7-8, 2003. ,
DOI : 10.1016/S0013-7944(02)00167-4
URL : https://hal.archives-ouvertes.fr/hal-01009018
An elasto-plastic damage model for reinforced concrete with minimum number of material parameters, Computers & Structures, vol.82, issue.15-16, pp.1201-1215, 2004. ,
DOI : 10.1016/j.compstruc.2004.03.002
Shell finite element of reinforced concrete for internal pressure analysis of nuclear containment building, Nuclear Engineering and Design, vol.241, issue.2, pp.515-525, 2011. ,
DOI : 10.1016/j.nucengdes.2010.11.008
Analysis of nonlocal models through energetic formulations, Int. J. Solids Struct, vol.42, issue.12, pp.2905-2936, 2003. ,
Gradient damage models: Toward full-scale computations, Computer Methods in Applied Mechanics and Engineering, vol.200, issue.21-22, pp.21-221927, 1944. ,
DOI : 10.1016/j.cma.2010.06.025
Nonlinear Mechanics of Reinforced Concrete, 2003. ,
Reinforced concrete structures under extreme loading: Stress resultant Global Reinforced Concrete Models (GLRC) In: COMPDYN, Comput. Meth. in Struct. Dyn. and Earthq. Eng, 2007. ,
Tension Chord Model for Structural Concrete, Structural Engineering International, vol.8, issue.4, pp.287-298, 1998. ,
DOI : 10.2749/101686698780488875
A new modelling strategy for the behaviour of shear walls under dynamic loading, Earthquake Engineering & Structural Dynamics, vol.25, issue.4, pp.937-954, 2002. ,
DOI : 10.1080/12795119.1997.9692120
URL : https://hal.archives-ouvertes.fr/hal-01004915
Concrete-Steel Construction, 1909. ,
Elastoplastic-damage modelling including the gradient of damage: formulation and computational aspects, International Journal of Solids and Structures, vol.38, issue.30-31, pp.5421-5451, 2001. ,
DOI : 10.1016/S0020-7683(00)00358-9
Finite element analysis of reinforced concrete beams, ACI J, vol.64, pp.152-163, 1967. ,
Seismic performance check and size effect FEM analysis of reinforced concrete, Engineering Fracture Mechanics, vol.65, issue.2-3, pp.369-389, 2000. ,
DOI : 10.1016/S0013-7944(99)00122-8
Contribution à l'analyse d'éléments en béton armé sollicités en membrane et flexion bi-axiale, 1995. ,
On micro-to-macro transitions for multi-scale analysis of non-linear heterogeneous materials: unified variational basis and finite element implementation, Int. J. Numer. Methods Eng, vol.87, pp.1-5, 2011. ,
Nonlocal Damage Theory, Journal of Engineering Mechanics, vol.113, issue.10, pp.1512-1533, 1987. ,
DOI : 10.1061/(ASCE)0733-9399(1987)113:10(1512)
Extended cracked membrane model for the analysis of RC panels, Engineering Structures, vol.32, issue.8, pp.1964-1975, 2010. ,
DOI : 10.1016/j.engstruct.2010.02.030
Tensile Tests and Failure Analysis of Concrete, Journal of Structural Engineering, vol.112, issue.11, pp.2462-2477, 1986. ,
DOI : 10.1061/(ASCE)0733-9445(1986)112:11(2462)
Homogenization-based modeling of reinforced concrete in the context of durability-oriented analyses, ECCOMAS Thematic Conference on Computational Methods in Structural Dynamics and Earthquake Engineering, 2007. ,
Modeling of reinforced concrete by means of homogenization approach including steel?concrete interactions, p.8, 2008. ,
Simplified P-Delta analysis for asymmetric structures, ASCE J. Struct. Div, vol.1089, 1982. ,
Non-Homogeneous Media and Vibration Theory, 1980. ,
Homogenization Technique for Composite Media, 1987. ,
DOI : 10.1007/3-540-17616-0
Analytical model for concrete confinement in tied columns, ASCE J. Struct. Div, vol.108, issue.12, pp.2703-2722, 1982. ,
A constitutive model for analysis of reinforced concrete solids. Can, J. Civ. Eng, vol.24, pp.460-470, 1997. ,
A coupled elastoplastic damage model for semi-brittle materials and extension to unsaturated conditions, Mechanics of Materials, vol.38, issue.3, pp.218-232, 2006. ,
DOI : 10.1016/j.mechmat.2005.07.002
URL : https://hal.archives-ouvertes.fr/hal-00021987
Computational model for post cracking analysis of RC membrane elements based on local stress???strain characteristics, Engineering Structures, vol.25, issue.8, pp.993-1007, 2003. ,
DOI : 10.1016/S0141-0296(03)00042-7
Localized nonlinearity and size-dependent mechanics of in-plane RC element in shear, Engineering Structures, vol.27, issue.6, pp.891-908, 2005. ,
DOI : 10.1016/j.engstruct.2005.01.011
FIBRE BEAM-COLUMN MODEL FOR NON-LINEAR ANALYSIS OF R/C FRAMES: PART I. FORMULATION, Earthquake Engineering & Structural Dynamics, vol.25, issue.7, pp.711-725, 1996. ,
DOI : 10.1002/(SICI)1096-9845(199607)25:7<711::AID-EQE576>3.0.CO;2-9
Nonlinear Analysis of Steel-Concrete Composite Structures: State of the Art, Journal of Structural Engineering, vol.130, issue.2, pp.159-168, 2004. ,
DOI : 10.1061/(ASCE)0733-9445(2004)130:2(159)
On Micro-Macro Transition in Non-Linear Mechanics, Materials, vol.21, issue.12, pp.296-317, 2010. ,
DOI : 10.1016/S0065-2156(08)70330-2
URL : https://hal.archives-ouvertes.fr/hal-00456089
Overall potentials and extremal surfaces of power law or ideally plastic composites, Journal of the Mechanics and Physics of Solids, vol.41, issue.6, pp.981-1002, 1993. ,
DOI : 10.1016/0022-5096(93)90051-G
Modified compression field theory for reinforced concrete elements subjected to shear, ACI J, vol.83, pp.219-231, 1986. ,
Reinforced concrete response to simulated earthquakes, J. Struct. Div, vol.96, issue.12, pp.2557-2573, 1970. ,
