Comparaison des Modèles et Architectures pour un Accès Mobile Restreint et Local au Web de Données - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2017
A Survey of the Models and Architectures for Restricted and Local Mobile Access for Web of Data
This document presents a survey prior to a thesis project, which aims to propose solutions allowing local and restricted access to the Web of data. We have explored several relevant mechanisms proposed in the literature, dedicated to various problems and likely to constitute important points for our future contributions. Since our main objective is to offer tools dedicated to mobility situations in environments where internet access is unreliable, we were particularly interested in comparing approaches (P2P, DHT, etc.) allowing to realize a particular fog/edge computing scenario which is restricted and local mobile access to contextually relevant and shared related data. In this context, we have focused some of our research on so-called gossip protocols (or epidemic protocols) that are well suited to the dynamic nature of networks. The dynamic aspect of the peers also led us to consider the solutions that take into account the location of the peers in order to improve the quality of the services offered. In addition, we looked at solutions dealing with semantic heterogeneity in peer-to-peer environments, including ontology alignment mechanisms that allow us to fully benefit from the power of peer-to-peer systems without imposing the use of a common ontology to all peers. Data replication and caching can be an important alternative to accessing remote sources; we have devoted the last part of this document to solutions based on these mechanisms to supply a local access to data.
Ce document présente un état de l'art préalable à un projet de thèse qui vise à proposer des solutions permettant un accès local et restreint au Web de données. Nous avons exploré plusieurs mécanismes pertinents proposés dans la littérature, dédiés à des problématiques différentes et pouvant constituer des points importants pour nos futures contributions. Notre objectif principal étant de proposer des outils dédiés à des situations de mobilité dans des environnements ou l’accès internet est peu fiable, nous nous sommes intéressés particulièrement à comparer des approches (P2P, DHT, etc.) permettant de réaliser un scénario de fog/edge computing particulier qui est l'accès mobile restreint et local à des données liées contextuellement pertinentes et partagées. Dans cette optique, nous avons focalisé une partie de nos recherches bibliographiques sur les protocoles dits de « gossip » (ou protocoles épidémiques) qui s’avèrent bien adaptés au caractère dynamique des réseaux. L'aspect dynamique des pairs nous a aussi amené à considérer des solutions qui prennent en compte la localisation des pairs pour améliorer la qualité des services offerts. Nous regardons de plus dans ce document, des solutions traitant de l’hétérogénéité sémantique dans des environnements pair-à-pair, notamment des mécanismes d’alignements d’ontologies qui permettent de profiter pleinement de la puissance des systèmes pair-à-pair sans imposer l’utilisation d’une ontologie commune à tous les pairs. La réplication et le cache de données pouvant constituer une alternative importante à l’accès à des sources distantes, nous avons consacré la dernière partie de ce document aux solutions reposant sur ces mécanismes et offrant ainsi un accès local aux données.
RR-9121.pdf (1.17 Mo) Télécharger le fichier
hal-01634219 , version 1 (13-11-2017)
  • HAL Id : hal-01634219 , version 1
Mahamadou Toure, Fabien Gandon, Kaladzavi Guidedi, Christophe Guéret, Moussa Lô, et al.. Comparaison des Modèles et Architectures pour un Accès Mobile Restreint et Local au Web de Données : Un état de l’art des architectures et solutions envisageables. [Rapport de recherche] RR-9121, INRIA Sophia Antipolis. 2017, pp.81. ⟨hal-01634219⟩
424 Consultations
1202 Téléchargements
