The forwarding indices of graphs - a survey, Opuscula Mathematica, vol.33, issue.2 ,
DOI : 10.7494/OpMath.2013.33.2.345
On the edge forwarding index problem for small graphs, Networks, vol.37, issue.38, pp.249-255, 1993. ,
DOI : 10.1111/j.1469-1809.1939.tb02219.x
The Forwarding Indices of Random Graphs, Random Structures & Algorithms, vol.23, issue.1, 1992. ,
DOI : 10.1080/01621459.1963.10500830
The forwarding index of communication networks with given connectivity, Discrete Applied Mathematics, vol.37, issue.38, pp.37-38, 1992. ,
DOI : 10.1016/0166-218X(92)90129-X
The forwarding index of communication networks, IEEE Transactions on Information Theory, vol.33, issue.2, pp.224-232, 1987. ,
DOI : 10.1109/TIT.1987.1057290
On forwarding indices of networks, Discrete Applied Mathematics, vol.23, issue.2, pp.103-123, 1989. ,
DOI : 10.1016/0166-218X(89)90022-X
URL : https://doi.org/10.1016/0166-218x(89)90022-x
Expanding and forwarding, Discrete Applied Mathematics, vol.58, issue.1, pp.67-78, 1995. ,
DOI : 10.1016/0166-218X(93)E0118-I
Some applications of Laplace eigenvalues of graphs, Graph Symmetry NATO ASI Series, pp.225-275, 1997. ,
DOI : 10.1007/978-94-015-8937-6_6
Multicommodity max-flow min-cut theorems and their use in designing approximation algorithms, Journal of the ACM, vol.46, issue.6, pp.787-832, 1999. ,
DOI : 10.1145/331524.331526
URL : http://www.cs.ust.hk/mjg_lib/bibs/qzhang_lib/Others/p787-leighton.pdf
The geometry of graphs and some of its algorithmic applications, Combinatorica, vol.15, pp.577-591, 1994. ,
Improved Bounds for Mixing Rates of Markov Chains and Multicommodity Flow, Combinatorics, Probability and Computing, vol.11, issue.04, pp.351-370, 1992. ,
DOI : 10.1016/0095-8956(89)90029-4
Power Awareness in Network Design and Routing, IEEE INFOCOM 2008, The 27th Conference on Computer Communications, 2008. ,
DOI : 10.1109/INFOCOM.2008.93
URL : http://www.cs.wisc.edu/~pb/infocom08a_final.pdf
Energy profile aware routing, in: Communications Workshops, pp.1-5, 2009. ,
Reducing Power Consumption in Backbone Networks, 2009 IEEE International Conference on Communications, 2009. ,
DOI : 10.1109/ICC.2009.5199404
URL : http://www.telematica.polito.it/mellia/papers/Icc09_GreenNet.pdf
Energy consumption in IP networks, 34th European Conference on, p.4729102, 2008. ,
Minimization of network power consumption with redundancy elimination, pp.247-258 ,
DOI : 10.1007/978-3-642-30045-5_19
URL : https://hal.archives-ouvertes.fr/hal-00721855
Optimizing rule placement in softwaredefined networks for energy-aware routing, Proceedings of the IEEE Global Communications Conference (GLOBECOM), 2014. ,
DOI : 10.1109/glocom.2014.7037187
URL : https://hal.archives-ouvertes.fr/hal-00996780
Minimizing Routing Energy Consumption: From Theoretical to Practical Results, 2010 IEEE/ACM Int'l Conference on Green Computing and Communications & Int'l Conference on Cyber, Physical and Social Computing, 2010. ,
DOI : 10.1109/GreenCom-CPSCom.2010.147
URL : https://hal.archives-ouvertes.fr/hal-00531468
Closing the Gap in the Capacity of Wireless Networks Via Percolation Theory, IEEE Transactions on Information Theory, vol.53, issue.3, pp.1009-1018, 2007. ,
DOI : 10.1109/TIT.2006.890791
Exposure in wireless Ad-Hoc sensor networks, Proceedings of the 7th annual international conference on Mobile computing and networking , MobiCom '01, pp.139-150, 2001. ,
DOI : 10.1145/381677.381691
Objects Tracking Utilizing Square Grid Rfid Reader Antenna Network, Journal of Electromagnetic Waves and Applications, vol.40, issue.1, pp.27-38, 2008. ,
DOI : 10.1109/8.127405
Tracking via Square Grid of RFID Reader Positioning and Diffusion Algorithm, Wireless Personal Communications, vol.40, issue.1, pp.227-250, 2011. ,
Probabilistic broadcast for flooding in wireless mobile ad hoc networks, 2003 IEEE Wireless Communications and Networking, 2003. WCNC 2003., pp.1124-1130, 2003. ,
DOI : 10.1109/WCNC.2003.1200529
URL : http://icwww.epfl.ch/publications/documents/IC_TECH_REPORT_200254.pdf
Measurement driven deployment of a two-tier urban mesh access network, Proceedings of the 4th international conference on Mobile systems, applications and services , MobiSys 2006, pp.96-109, 2006. ,
DOI : 10.1145/1134680.1134691
Power control in two-tier femtocell networks, IEEE Transactions on Wireless Communications, vol.8, issue.8, pp.4316-4328, 2009. ,
DOI : 10.1109/TWC.2009.081386
URL : http://arxiv.org/pdf/0810.3869
Design of a wireless backhaul network for microcells, WCNC. 1999 IEEE Wireless Communications and Networking Conference (Cat. No.99TH8466), pp.428-432, 1999. ,
DOI : 10.1109/WCNC.1999.797861
A Tractable Approach to Coverage and Rate in Cellular Networks, IEEE Transactions on Communications, vol.59, issue.11, pp.3122-3134, 2011. ,
DOI : 10.1109/TCOMM.2011.100411.100541
URL : https://hal.archives-ouvertes.fr/hal-00940544
Honeycomb networks: Topological properties and communication algorithms, IEEE Transactions on Parallel and Distributed Systems, vol.8, issue.10, pp.1036-1042, 1997. ,
DOI : 10.1109/71.629486
URL : http://www.site.uottawa.ca/~ivan/tpds-honey.pdf
Pipelined communications in optically interconnected arrays, Journal of Parallel and Distributed Computing, vol.12, issue.3, pp.269-282, 1991. ,
DOI : 10.1016/0743-7315(91)90130-2
Stochastic geometry and random graphs for the analysis and design of wireless networks, IEEE Journal on Selected Areas in Communications, vol.27, issue.7, pp.1029-1046, 2009. ,
DOI : 10.1109/JSAC.2009.090902
Embedding planar graphs on the grid, in: SoDA, pp.138-148, 1990. ,
Energy Efficient Routing by Switching-Off Network Interfaces, IGI Global, 2012, Ch. 10 -Energy- Aware Systems and Networking for Sustainable Initiatives, pp.207-236 ,
DOI : 10.4018/978-1-4666-1842-8.ch010
URL : http://arxiv.org/abs/1410.1076
On the Problem of Partitioning Planar Graphs, SIAM Journal on Algebraic Discrete Methods, vol.3, issue.2, pp.229-240, 1982. ,
DOI : 10.1137/0603022
How to Design Graphs with Low Forwarding Index and Limited Number of Edges, 26th International Workshop on Combinatorial Algorithms, 2015. ,
DOI : 10.1007/978-3-319-29516-9_19
URL : https://hal.archives-ouvertes.fr/hal-01221650
