String Stability towards Leader thanks to Asymmetric Bidirectional Controller - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Alain Sarlette
  • Fonction : Auteur
  • PersonId : 10453
  • IdHAL : asarlet
This paper deals with the problem of string stability of interconnected systems with double-integrator open loop dynamics (e.g. acceleration-controlled vehicles). We analyze an asymmetric bidirectional linear controller, where each vehicle is coupled solely to its immediate predecessor and to its immediate follower with different gains in these two directions. We show that in this setting, unlike with unidirectional or symmetric bidirectional controllers, string stability can be recovered when disturbances act only on a small (N-independent) set of leading vehicles. This improves existing results from the literature with this assumption. We also indicate that string stability with respect to arbitrarily distributed disturbances cannot be achieved with this controller.
Published-Arxiv.pdf (536.41 Ko) Télécharger le fichier
hal-01634578 , version 1 (14-11-2017)
Arash Farnam, Alain Sarlette. String Stability towards Leader thanks to Asymmetric Bidirectional Controller. IFAC World congres 2017, Jul 2017, Toulouse, France. ⟨10.1016/j.ifacol.2017.08.1673⟩. ⟨hal-01634578⟩
524 Consultations
133 Téléchargements
