When Does Memory Speed-up Mixing? - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We investigate under which conditions a higher-order Markov chain, or more generally a Markov chain on an extended state space, can mix faster than a standard Markov chain on a graph of interest. We find that, depending on the constraints on the dynamics, two very different scenarios can emerge: under strict invariance of the target marginal and for general initialization of the lifted chain no speedup is possible; on the other hand, if these requirements are both relaxed, the lifted dynamics can achieve mixing in a time that corresponds to the diameter of the graph, which is optimal.
Mixing-CDC-Final.pdf (268.3 Ko) Télécharger le fichier
hal-01634630 , version 1 (14-11-2017)
  • HAL Id : hal-01634630 , version 1
Simon Apers, Alain Sarlette, Francesco Ticozzi. When Does Memory Speed-up Mixing?. IEEE Conference on Decision and Control, Dec 2017, Melbourne, Australia. ⟨hal-01634630⟩
462 Consultations
239 Téléchargements
